Replaced blower motor resistor and fan still does not work #938797 04/04/09 06:40 PM
mattd Offline OP
Just finished replaced my blower motor resistor and the fan still does not work on any of the speeds. I'm thinking it might be the fan. I have already taken it out and was wondering if their is a way to test it to see if it spins.
Re: Replaced blower motor resistor and fan still does not work [Re: mattd] #938798 04/04/09 06:54 PM
BigJim Offline
Sure, hit it with 12V.. But be careful it will JUMP violently if it works.. You won't be able to hold it.
Re: Replaced blower motor resistor and fan still does not work [Re: BigJim] #938799 04/04/09 07:17 PM
mattd Offline OP
I'm assuming I touch the battery with the red wire, and should I ground the black one?
Re: Replaced blower motor resistor and fan still does not work [Re: mattd] #938800 04/04/09 08:23 PM
BigJim Offline
Yep! Make sure to have it insulated from the battery..or donor vehicle.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5989 MB (Peak: 0.6538 MB) Data Comp: Off Server Time: 2026-07-13 18:04:26 UTC
