Page 1 of 4 1 2 3 4
build your own k&n cold air intake #938919 04/05/09 05:59 PM
londart Offline OP
this works great for a 95 dohc, i assume it will work on 95-02 since they use the same maf.all you need are three things that should cost less than a k&n stock replacement filter,and im sure gives more hp gains and clears out the engine compartment very nicely.
k&n # ru3610 (universal cone filter w/2 3/4 id flange)
1" of dayco # 76250 (2 1/2" straight rad hose)
stant # 10072 (rubber gm oil filler cap)
remove all stock filter housing, rubber intake hose and that little black box, but leave the rubber connector for the lil box on the engine.use the stant oil plug to plug this and use the original clamp to tighten it.take off the rubber connector from the maf to the stock air box, put the dayco straight rad hose in the larger end of this and place on the intake pipe, use the original clamp to tighten this.next put the maf on the other end of the rubber connector and use the original clamp to tighten.lastly put the k&n on the other side of the maf and use the supplied clamp to tighten.voila, your very own cold air intake!!!!!
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: build your own k&n cold air intake [Re: londart] #938920 04/06/09 12:01 AM
bombardj1 Offline
how about pics, we love pics here.
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: build your own k&n cold air intake [Re: bombardj1] #938921 04/06/09 12:26 AM
londart Offline OP
Lonnie
Re: build your own k&n cold air intake [Re: londart] #938922 04/06/09 03:45 AM
londart Offline OP
thanks for the help with the pics everet, it worked great
Lonnie
Re: build your own k&n cold air intake [Re: londart] #938923 04/06/09 04:31 AM
jays2001 Offline
awesome <img src="/forums/images/graemlins/kewl.gif" alt="" /> was thinking of doing that but wasn't sure it would work but seeing is believing and makes room for my second battery <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: build your own k&n cold air intake [Re: londart] #938924 04/06/09 04:57 AM
Iron Offline
Great work! Did something similar a few years back, you may want to fab up a box around the filter to protect it against heat from the header which is a few inches away and from debris. I did that then cut a hole in the hood and made an intake to the filter would draw in cold air from the outside and not use hot engine bay air, and sealed the box to the hood to limit the amount of warm air the CAI would draw in!!
[Linked Image] [Linked Image] [Linked Image] [Linked Image]
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: build your own k&n cold air intake [Re: londart] #938925 04/06/09 04:57 AM
6
69442 Offline
Sweet, that's a quick and inexpensive upgrade that delivers. Thanks dude! <img src="/forums/images/graemlins/kewl.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: build your own k&n cold air intake [Re: 69442] #938926 04/07/09 07:00 AM
fokion Offline
Experience showed that you are running great up to the point the engene reaches working temperature
then you run worst....
Yew ok the sound is great but you have lost too much
unless is -10 degrees the outside temp.
Re: build your own k&n cold air intake [Re: fokion] #938927 04/07/09 03:04 PM
k120189 Offline
its not only temp its restriction. lets face it the intake tube goes right over the engine any air we draw in is going to be warm. if not hot. goin with a cone filter (mine is liek iron's) is less restrictive then the stock airbox and it does really open up your engine bay (i've been wanting dual batteries as well) that and my thermostat died so my engine never reaches the normal operating temp. i did notice more throttle response doing this. give it a try
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: build your own k&n cold air intake [Re: fokion] #938928 04/07/09 04:18 PM
londart Offline OP
mine has definately been to operating temp and still runs great...it cleans up the engine bay and gives more flow, just try and see,it works...originally i used the stock rubber intake tube but mine was cracked pretty bad so i did it this way, besides on a cai u dont want to used a ribbed hose that causes restriction too, so if u want to move it farther away from headers try to fab something without the ribs...glad to see it at least has people talking, well off to work now, time to sell some auto parts
Lonnie
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 2.322s Queries: 16 (0.004s) Memory: 0.6403 MB (Peak: 0.7653 MB) Data Comp: Off Server Time: 2026-06-19 06:42:10 UTC
