build your own k&n cold air intake
#938919
04/05/09 05:59 PM
this works great for a 95 dohc, i assume it will work on 95-02 since they use the same maf.all you need are three things that should cost less than a k&n stock replacement filter,and im sure gives more hp gains and clears out the engine compartment very nicely. k&n # ru3610 (universal cone filter w/2 3/4 id flange) 1" of dayco # 76250 (2 1/2" straight rad hose) stant # 10072 (rubber gm oil filler cap)
remove all stock filter housing, rubber intake hose and that little black box, but leave the rubber connector for the lil box on the engine.use the stant oil plug to plug this and use the original clamp to tighten it.take off the rubber connector from the maf to the stock air box, put the dayco straight rad hose in the larger end of this and place on the intake pipe, use the original clamp to tighten this.next put the maf on the other end of the rubber connector and use the original clamp to tighten.lastly put the k&n on the other side of the maf and use the supplied clamp to tighten.voila, your very own cold air intake!!!!!
Lonnie Auto Parts Professional 95 sportage sold but not forgotten
Re: build your own k&n cold air intake
[Re: londart]
#938920
04/06/09 12:01 AM
how about pics, we love pics here.
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
[Re: bombardj1]
#938921
04/06/09 12:26 AM
[Re: londart]
#938922
04/06/09 03:45 AM
thanks for the help with the pics everet, it worked great
[Re: londart]
#938923
04/06/09 04:31 AM
awesome <img src="/forums/images/graemlins/kewl.gif" alt="" /> was thinking of doing that but wasn't sure it would work but seeing is believing and makes room for my second battery <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
[Re: londart]
#938924
04/06/09 04:57 AM
08' Jeep Wrangler 64' Plymouth Sport Fury 383 58' Triumph TR-3A
[Re: londart]
#938925
04/06/09 04:57 AM
Sweet, that's a quick and inexpensive upgrade that delivers. Thanks dude! <img src="/forums/images/graemlins/kewl.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting ..... ____o_o l_l_l\___\___ l----[o]==[o] l----==[--]== ()_)()_)--()_)
[Re: 69442]
#938926
04/07/09 07:00 AM
Experience showed that you are running great up to the point the engene reaches working temperature then you run worst.... Yew ok the sound is great but you have lost too much unless is -10 degrees the outside temp.
'96 4d mechanicaly stock so far, rims, spoiler, Cooper AT tyres, Factory LSD, Manual Warn Hubs, handmade exaust, ELECTRIC FAN!!! 3,1'' Lift, PALM GPS http://members.cardomain.com/fokion
[Re: fokion]
#938927
04/07/09 03:04 PM
its not only temp its restriction. lets face it the intake tube goes right over the engine any air we draw in is going to be warm. if not hot. goin with a cone filter (mine is liek iron's) is less restrictive then the stock airbox and it does really open up your engine bay (i've been wanting dual batteries as well) that and my thermostat died so my engine never reaches the normal operating temp. i did notice more throttle response doing this. give it a try
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
[Re: fokion]
#938928
04/07/09 04:18 PM
mine has definately been to operating temp and still runs great...it cleans up the engine bay and gives more flow, just try and see,it works...originally i used the stock rubber intake tube but mine was cracked pretty bad so i did it this way, besides on a cai u dont want to used a ribbed hose that causes restriction too, so if u want to move it farther away from headers try to fab something without the ribs...glad to see it at least has people talking, well off to work now, time to sell some auto parts
