Re: build your own k&n cold air intake
[Re: londart]
#938939
04/14/09 08:16 AM
Thats pretty cool,must be available in australia only huh,havent seen here in the states,or is it homemade? Lonnie, Lucked out on Ebay through a guy I was originally sourcing through in Aus. He gets these snorkels from Taiwan. He owns his own business for Suzuki Parts. You can try and contact him on the following website http://www.4wdmonthly.com.au/forum/He goes under the handle of ODA1. ry in the suzuki area. Cheers, Chris
97 Sporty, snorkel, K&N filter,chipped, ext forks, 40mm Dob Springs, KYB struts, 35mm Jeep TJ Springs, RAV 4 OME shocks, Kaiser Locker 5.38 R&P's, 1&3/8 body lift, 245/75 R16 D674's Sports steering wheel, bullbar, extractors & 2 1/4 exhaust engineered.
Re: build your own k&n cold air intake photos of snorkel fitting
[Re: 4runnernomore]
#938940
04/14/09 08:47 AM
[Re: londart]
#938941
04/15/09 02:11 PM
Basicly what Iron was pointing out is it's not a cold air intake unless you isolate it from the rest of the heat under the hood. Mine is simular to Iron's without the box, it does work great but it's not a cold air intake.
Dennis
95 Sportage, gone but not forgotten. 98 Jeep TJ, 4" Zone springs with RC Long arms, Ford 8.8", 4.56 gears & Detroit locker rear, D30, 4.56 & Detroit Trutrack front.
[Re: DennisThompson]
#938942
04/16/09 06:39 AM
Thanks for the picks my friend..
'96 4d mechanicaly stock so far, rims, spoiler, Cooper AT tyres, Factory LSD, Manual Warn Hubs, handmade exaust, ELECTRIC FAN!!! 3,1'' Lift, PALM GPS http://members.cardomain.com/fokion
[Re: fokion]
#938943
05/02/09 03:28 PM
Hey, Is there have to be a filter specific for air filter in our kia's or can i really just be at choice? Ever since my Straight through design exhaust my intake seems to be trying to suck harder for my air. Thinking of possiblities other then that cone like filter. I found a tube looking one that is appx. 4" long and 3" dia. Found it at John deer trackers equipment. Was going to make somthing of it but damn the hot air really does build up under out hoods. and I don't wanna do a snorkel don't wanna cut the frame at this point.
[Re: Macneal]
#938944
05/02/09 07:50 PM
anybody ever try header wrap or header paint to reduce the heat under our hoods???
Lonnie Auto Parts Professional 95 sportage sold but not forgotten
[Re: londart]
#938945
05/03/09 12:41 AM
And what to do with the Intake Air Temperature Sensor ? Starring at it thinking i could just get a 2" piece of pipe and drill a hole and stick it in but then again would that work? Or do we even need this thing?
[Re: Macneal]
#938946
05/03/09 01:37 AM
my 95 doesnt have that, but if yours has it, pretty sure the computer needs it or it can screw with mpg and other fuel delivery probs if you just leave it unplugged(at least thats what ive been told by customers looking to buy them for their rigs), it would at least throw a code on turn on your CEL...u should just be able to drill a hole in the pipe you suggested and weld the correct size nut over the hole so that you can thread the sensor back in, same concept as an O2 sensor bung on a custom exhaust
[Re: londart]
#938947
05/03/09 09:00 AM
Well, Atleast now I someone tells me the same thing I was thinking I gonna try it. Thank you Londart. Since my Straight pipe into a glasspack the motor seems to be demanding more air intake I need to do something about it. Hope this Setup I have in mind will satisfy the motor. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: Macneal]
#938948
05/04/09 01:54 AM
anybody ever try header wrap or header paint to reduce the heat under our hoods??? Do NOT try header wrap! header wrap has a nasty habit of causing manifolds to crack at the welds. Not just in Kia's but in general. Wrap really isn't ment for everyday driving, and actually works better on cast manifolds. A simple heat shield would work a lot better, be alot cheaper and was esayer to install.
08' Jeep Wrangler 64' Plymouth Sport Fury 383 58' Triumph TR-3A
