Re: Axle Widths (WMS-WMS)
[Re: Alex Kogan]
#939266
04/09/09 06:44 AM
not to go to off topic but u guys and ur extensive knowledge is impressive, im a inspirering raider/monty man and was wonder on a 89swb raider whar the gear ratios are, and how hard would it be to put disks brakes on the back? thanks
"No obstacle brute force and ignorance cant overcome" 89 SWB RAIDER (IN PIECES) 06 F250 SuperDuty Axles Currently saving for F-O-A 18" Coilovers Cummins 6bta/5r110w/np271
[Re: Temple]
#939267
04/09/09 07:08 AM
Your gears will be on the plate in the engne bay. Between the Gen I and II, one is usually 4.625 and the other 4.636. I never remember which without looking at mine.
As for the rear disks, how is your rear sprung now on the 89? If coils, best overall route is to swap an SR locking axle in. No real "upgrades" to the stock drum axle. Some overseas market I think had rear disk possibilites.
[Re: MontyMcV]
#939268
04/09/09 12:23 PM
Gen1s had 4.625 gen2 4.636. Overseas some had disc brakes on gen1s. You could swap if a v6 you could swap the whole axle. If a 4 cyl, you could get a Montero sport axle with disc brakes. Both of those are also available with a locker.
[Re: Alex Kogan]
#939269
04/09/09 06:17 PM
Did any big axle Monteros come with 4.9s factory?? Did the sports come with them factory? Thanks again everyone
[Re: Ruination_Fan]
#939270
04/09/09 07:08 PM
bid axle Montero(Pajero) with 4.9 was only available overseas on 2.8TD version. Montero Sport 2000+ 3.5L versions came with 4.9 in big axle but didn't have selectable locker. They only had LSD (all of Ltd and some of XLSs) albeit very good (possibly best?) one. I you want to install locker into that you would need 3rd member and axles out of 98-99 Monty. They either swap R&P or modify existing house to accept airline and switch, and swap lockable differential only.
Alternatively you can get M/S axle and install new ARB locker which are just coming out.
92 SR, 285/75R16 Yoko MT ARB locker GAST compressor AirLift 1000 MM10500 Snorkel custom rear bumper 02 Montero LS died protecting the master 08 PowerWagon (stock!)
[Re: Alex Kogan]
#939271
04/10/09 02:07 AM
Thanks again Alex. So...if tney have Montero sport, it may have 4.9 ratio gears? Are these axles tagged, or are they listed on the door jamb sticker or underhood? So right now...if the moons align at the junk yard.....get the 95 SR rear axle.....and if a montero sport is around with 4.9 gears.....steal the gears and swap them onto the 95 SR 3rd member (of course setting up properly with checking backlash and teeth pattern...yada yada yada). Thanks again for all the info...this has been extremly helpful. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: Ruination_Fan]
#939272
04/10/09 04:28 PM
Yes you can do that. Also you can find those on 01-02 4 speed Montero with IRS.
[Re: Alex Kogan]
#939273
04/10/09 06:29 PM
Awesome. Thanks again Alex and everyone. I will keep you posted on the find at the JY this weekend.
[Re: Alex Kogan]
#939274
04/10/09 06:59 PM
Also....are the gear ratios stamed on the 3rd members, or ID tagged on the 3rd members....or...is there an ID sticker on the door jamb or hood listing the gear ratio? Thanks againe everyone.
[Re: Ruination_Fan]
#939275
04/10/09 07:10 PM
Also....are the gear ratios stamed on the 3rd members, or ID tagged on the 3rd members....or...is there an ID sticker on the door jamb or hood listing the gear ratio? Thanks againe everyone. Inside the engine bay, attached to the passenger side firewall is a plate and one row on the plate says.....oh man, can't remember exactly....'transaxle' (?) and then the R&P ratio. For example 4.272 gears will read 4272 on the plate. <img src="/forums/images/graemlins/kewl.gif" alt="" />
