JK Front Fender removal?
#940344
04/15/09 02:14 AM
Hi Guys!
Anyone have or know of a write up on how to remove the front passenger side plastic fender flare on a 08' JK?
I'm installing my River Raider snorkel and need to get the fender off!
also how do you remove the radio antenna and bezel?
Thanks in advance!
Mike B
08' Jeep Wrangler 64' Plymouth Sport Fury 383 58' Triumph TR-3A
Re: JK Front Fender removal?
[Re: Iron]
#940345
04/16/09 03:33 AM
If it's the same old way as usual, reach up in there and find the platic/ rubber things that the screws go into from the fender. Hold 'em tight and back out the screws. Keep all the hardware - you'll need it again. You can pull up the inner plastic fenders to get at the hardware. Yank it around to get where you need - it's pretty forgiving. If it's held in place with plastic anchors you can get new ones at Lowes or local Pep Boys, Advance Auto, Etc.
97tj, Shaved Ford 9 rear, 4:10's, New 35x12.5 BFG KM2's to test!, Warn x8000i, ARB's, Quick Disco's, Hand Throttle, & it's my DD.
PHP: 7.4.33 Page Time: 1.279s Queries: 15 (0.004s) Memory: 0.5864 MB (Peak: 0.6341 MB) Data Comp: Off Server Time: 2026-06-16 16:34:23 UTCValid HTML 5 and Valid CSS
