Re: Fuel lever/door trouble [Re: Scottie2113] #940742 04/17/09 05:35 AM
mrr Offline OP
I tried the zip tie and it made the problem worse <img src="/forums/images/graemlins/frown.gif" alt="" />. It just made the lever even more difficult to pull on. <img src="/forums/images/graemlins/confused.gif" alt="" />
1995 SR
Re: Fuel lever/door trouble [Re: mrr] #940743 04/17/09 06:32 AM
Scottie2113 Offline
you must have another issue; yours must not just be a loose or stretched cable; I suspect it is kinked somewhere. I would check first behind the handle on the dash and then try to trace it to see if you can spot where it might be binding.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Fuel lever/door trouble [Re: MontyMcV] #940744 04/17/09 06:34 AM
Scottie2113 Offline
if your door is releasing and then catching again, that just means that it isn't pulling far enough to completely eject the door on its own, your cable is stretched and if you take up just a little bit of slack in it (i.e. the zip tie method) when you pull on it, it will pop it all the way out so it doesn't catch again and pull it back in.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6010 MB (Peak: 0.6540 MB) Data Comp: Off Server Time: 2026-06-09 23:20:00 UTC
