Rather than have half a page of sticky posts, we've decided to have 1 for the Forum Rules and this sticky with links to the former critical sticky threads.
Hope this helps make your trip through the forums easier...
Ray <img src="/forums/images/graemlins/kewl.gif" alt="" />
TECHNICAL REFERENCE DOWNLOADSFactory Service Manual download page
CLICK HERE Factory parts software program (CAPS/ASA) download & installation thread
CLICK HERE Vehicle VIN numbers for parts lookups or comparisons using the CAPS or Mitsu ASA program
CLICK HERE.
Technically this is not a download but it's very useful for the Mitsu ASA program if you don't have a vin number handy.TECHNICAL REFERENCE THREADSSpecialized Part Number Repository Thread
CLICK HERELight bulb reference thread
CLICK HEREPost of the most commonly used abbreviations
CLICK HERE1987 2.6L Vacuum diagram (Federal/Canada Model, Auto Transmission, no AC)
CLICK HERE3.0L SOHC 6G72 Specifications
CLICK HERE3.5L DOHC 6G74 Specifications
CLICK HERETurbo Conversion Bible Thread
CLICK HEREMITUSIBHI 4x4 FAQ's...
CLICK HEREMitsubishi Transmission Model Designations
CLICK HEREGen I & Gen II Parts Compatibility Thread
CLICK HEREGen I Transfer Case Options Thread
CLICK HEREMitsu super select description & meaning of blinking 4x4 lights
CLICK HERERing & Pinion Gear Options
CLICK HEREFM145 (similar to KM145) Manual Transmission internals (Pictures)
CLICK HEREMitsubishi Owners Map Project (N.Am.)
CLICK HEREParts Yard Alerts
CLICK HEREBolt Size thread
CLICK HERE Brake Specs (All Models) thread
CLICK HERETire Experiences thread
CLICK HEREGen I IFS Bearing & Seal Part Numbers thread
CLICK HEREMitsu V6 Temp Sensor Testing Page Image from Factory Manuals
CLICK HEREPART SOURCES: New, Used, OEM, Aftermarket, and/or Upgrade PartsUsed Parts4x4wire Mitsubishi "Pay It Forward" Thread
CLICK HEREMitsubishi & Saturn Recycling
CLICK HEREAmerican Nationwide Salvage Yard stock database
CLICK HEREAV-Pro Company (rebuilds ECU's/ECM's): Speak with Nick @ 239-849-0981
CLICK HEREOEM / Aftermarket Parts-
Rock Auto PartsCLICK HERE-
Korum Mitsubishi CLICK HERE-
Southwest Mitsubishi PartsCLICK HEREUpgrade Parts-150 Amp Alternator Source: Eagle Auto Electric, T: (818)718 2907 or (818)400 4941, 18246 Parthenia, Northridge, CA 91325
-Japanese Suspension Kits (Speaks some English)
CLICK HERE & their Main Page
CLICK HERE-Using Toyota shackles to replace mitsu shackles
CLICK HEREOWNER BUILDSFrank's G-Raider 3.0L Supercharger Project...
CLICK HEREBob's Rebuild via FrankR
CLICK HERERay's 96SR Build thread
CLICK HEREJustice's 89 v6 Montero Build thread
CLICK HEREPhil's 93 Exceed TDI Build thread
CLICK HEREHOW TO UPGRADE _____ THREADSGen I v6 disk brake calipers to a Gen II SR disk brake calipers
CLICK HERESAS (Solid Axle Swap) Discussion Thread
CLICK HEREHow to run 34" Tires Stock
CLICK HEREGen I Speedometer Gear Options for Running Larger Than Stock Tires
CLICK HEREInstalling 4Crawler.com's 2" Body Lift
CLICK HEREAnother Lift Install Thread
CLICK HERESwapping a Gen II SR axle into an 89 2 door v6 Montero/Raider
CLICK HERE Cap510 3.15:1 Transfer Case Installation
CLICK HEREWindow Regulator Motor Gear Rebuild
CLICK HEREGen II Flashing 4WD indicator lights
CLICK HERETo learn how to install Superwinch Manual Hubs
CLICK HERE How to install an Aussie Locker
CLICK HEREWinch Install Examples
CLICK HEREHow to add rubber fender flares
CLICK HEREHOW TO FIX / MAINTAIN THREADSHow to check ECU codes in a pre OBDII Mitsu 4x4
CLICK HERETroubleshooting super select 4x4 indicator problems
CLICK HERE or
CLICK HEREPCC's Thread on how he troubleshoot is 92 Montero's 4wd indicator light problem
CLICK HEREWhere to get Aisin Manual Hub parts
CLICK HEREHow to disable the dealer installed Gen 2.5 (98-00) vehicle immobilizer alarm system
CLICK HERECrankshaft Removal Tool
CLICK HERETo learn how to replace the Automatic Transmission Fluid in a Montero
CLICK HERE Working on the Starter by 4ePikanini
CLICK HEREBrake Light Staying Lit?
CLICK HERE How to fix a broken Crank Pulley Bolt
CLICK HEREDifferent Ways to loosen/tighten a crank bolt w/out a special tool.
CLICK HERE How to fix worn or Torn Inner CV Boots
CLICK HEREHow to fix Flashing 4x4 lights
CLICK HEREHow to fix Ticking V6 Lifter ticks
CLICK HEREHow to fix the V6 Crank Bolt issue
CLICK HEREHow to replace Anti-Sway Bar Bushings
CLICK HEREHow to replace your Ignition Switch
CLICK HERE Possible Poor Idle fix (Gen I '89 V6)
CLICK HEREReplacing your front wheel bearings and races
CLICK HERERebuilding your front end
CLICK HEREReplacing the Transmission Fluid in a Gen III Montero [http://www.4x4wire.com/forums/showflat.php?Cat=0&Number=1240537&Main=1240532]
CLICK HERE[/url]
How to open the rear cargo door with a broken handle and replace it.
CLICK HERERetrofitting a 1991 Montero Cruise Control into any Gen I Montero/Raider
CLICK HEREUsing Google to search 4x4WireIn case you're having difficulty searching for things using the forum's search engine, you can also use google to do the search. Here's a
post on how to do just that.
