Re: Location for an amplifier in a '92? I have dual bouncey seats... [Re: redbull] #941122 04/24/09 03:54 AM
Clead Offline OP
Ceiling between the front seats?
Sunroof.
Maybe attached to the back of the center console?
Rear heat and AC controls.
Funny, the only time being fully-loaded is a liability... <img src="/forums/images/graemlins/lol.gif" alt="" /> I'm going to pull the heat/AC rear plastics off this weekend and see if I could squeeze it in there somewhere. I hardly ever use it, and heatwise it's only a 4x40W amp. All Crutchfield users who mentioned heat at all only mentioned it to say that it didn't actually heat up, period. I guess if that doesn't work, I'll consider attaching it to the 2nd row seats with a flexible connection. Probably not a good choice because I do use my Pajero as a van fairly often. Argh!
Thanks for the suggestions guys.
I am now officially a Pajero owner. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />.
1992 Exceed w/winter pkg, roof tray, bounceys, the works smile
Re: Location for an amplifier in a '92? I have dual bouncey seats... [Re: redbull] #941123 04/24/09 06:45 PM
W
WagonMaster Offline
Sunroof.
Screwed?
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: Location for an amplifier in a '92? I have dual bouncey seats... [Re: WagonMaster] #941124 04/24/09 08:27 PM
redbull Offline
LOL!
Re: Location for an amplifier in a '92? I have dual bouncey seats... [Re: redbull] #941125 04/24/09 09:46 PM
Scottie2113 Offline
the US spec monteros that had factory infinity amps in them had a compartment under the 2nd row seat right side of vehicle as you sit in it. not sure if pajeros had that same compartment, but it is a large compartment and you can see it if you look just above the tire through the fender well gap between the frame and body.
you have to life the carpet up and there is a large metal plate bolted down, kinda like the plate to access the fuel pump on the gas tank, but instead, it is further frontwards and under the right second row seat. I can pics of mine on my montero if you need them.
97 Montero SR w/Mitsu Adj Shocks & Rear Diff Lock ARB Front Diff Lock 4.9 Ring/Pinion 3.15 transfer box 43:1 crawl ratio 2" suspen lift 2" body lift 2" Gas Tank Lift 35x12.5 MTRs 15x10 Wheels Rock Sliderz ARB front bumper w/12k winch Custom rear bumper
Re: Location for an amplifier in a '92? I have dual bouncey seats... [Re: Scottie2113] #941126 04/24/09 10:55 PM
Clead Offline OP
Pics of that would be great... if it doesn't help me, it'll help someone else with a Montero. I did a search and there were only passing references to amps and Pajeros/Monteros here, so this thread is our big reference for now, lol.
Re: Location for an amplifier in a '92? I have dual bouncey seats... [Re: Clead] #941127 04/24/09 11:23 PM
Scottie2113 Offline
I will try to remember, but if I forget, just pm me or something to remind me.
Re: Location for an amplifier in a '92? I have dual bouncey seats... [Re: Scottie2113] #941128 04/25/09 12:46 AM
redbull Offline
Sounds like where our rear heat fan is on the Pajeros. I should snap a pic to confirm.
Re: Location for an amplifier in a '92? I have dual bouncey seats... [Re: redbull] #941129 04/25/09 03:55 AM
Scottie2113 Offline
ok, here are my pics, the first three pics are of a 97 SR right rear wheel well, as you can see the big box hanging down, that is the compartment that the monteros had an infinity factory installed amplifier, most the box is empty as the amp didn't take up all that room. keep in mind, this truck had a 2 inch body lift, so if yours is stock it won't be as wide open and visible, but you get at it from under the carpet under the 2nd row seat.
now this pic is a 97 LS, this trim didn't come with the infinity system, so therefore, didn't have the compartment installed, here is a pic to show you what it looks like if you don't have it
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6367 MB (Peak: 0.7309 MB) Data Comp: Off Server Time: 2026-06-07 06:57:44 UTC
