Page 2 of 4 1 2 3 4
Re: Post up your callsign [Re: hochkis] #941462 04/22/09 02:19 AM
52degrees Offline OP
2-meter is pretty relaxed. Pretty much just identify yourself and don't use any of "the 7 words" <img src="/forums/images/graemlins/wink.gif" alt="" /> Remember that nets that run on whatever repeater you're on get priority (as a matter of etiquette) and you shouldn't have any problems.
KG6VNX
Re: Post up your callsign [Re: 52degrees] #941463 04/22/09 02:32 AM
hochkis Offline
Well the 7 words shouldn't be a problem. <img src="/forums/images/graemlins/smile.gif" alt="" /> I'll start looking into the repeaters here in NV/CA area, I've only been here for about 2.5 years.
95 Montero SR- Stock
90 Turbo Miata - TD04 wrx turbo, Flyin miata suspension, Torsen diff, 225 RS3's
92 Mighty Max 4x4 - Retired
Re: Post up your callsign [Re: hochkis] #941464 05/06/09 08:26 PM
What 7 words?
Re: Post up your callsign [Re: cmonty72] #941465 05/07/09 04:31 AM
kewlynx Offline
The FCC's 7 words. <img src="/forums/images/graemlins/rodent.gif" alt="" />
Note: NSFW, kids' ears. Use headphones.
Mr. Carlin, RIP
http://www.youtube.com/watch?v=TwelMWLBPik
**ubi apis- ibi salus**
Re: Post up your callsign [Re: kewlynx] #941466 05/07/09 04:58 PM
That explains alot. <img src="/forums/images/graemlins/wink.gif" alt="" />
My brother was in Guatamala with the 82nd Airborne. I used to talk to him through a militay operator..over. Anyway I was cussing up a storm until I got my ass chewed by the operator. <img src="/forums/images/graemlins/lol.gif" alt="" />
I also got a stern talking to from the harbor master on my dads MArine radio. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Post up your callsign [Re: 52degrees] #941467 06/21/09 01:46 PM
Dandeman Offline
Toyota Moderator
KR4UB.. Advanced... Trustee for W4UNC
Have been a repeater builder for quite a few years..
Our W4UNC repeaters:
442.150MHz (PL 131.8Hz) --the flagship, with coverage throughout Piedmont NC
443.475MHz (PL 131.8Hz) --local coverage in the Chapel Hill vicinity
145.230MHz (PL 107.2Hz) --soon with an IRLP link, we hope
53.450MHz (PL 107.2Hz) --improved coverage after June 12th?
Orange County Radio Amateurs (OCRA) Web Site http://www.ncocra.org/index.html
Pic at the 442.150 site..
Re: Post up your callsign [Re: Dandeman] #941468 06/26/09 12:41 AM
That's so cool!
I'm thinking again about going for my Extra class in July. I haven't been studying though.
KG6VNX
Re: Post up your callsign [Re: 52degrees] #941469 07/21/09 07:58 AM
BobRowe Offline
K1QD here. Extra.
First licensed, as WB6UQY, in 1968.
Re: Post up your callsign [Re: BobRowe] #941470 08/18/09 04:58 AM
RoryTek Offline
N6OIL used to be KE6NIG tech class someday when work isn't busting my chops I'll upgrade. I do mostly 70cm on a closed repeater system. Been hamming since the late 80's
Yeah I know it's a vanity call.
Rory N6OIL
88'Monty 2.6l 2dr,5spd,Silver,2 bouncy seats,LSD
Most Wanted Synthetics
Re: Post up your callsign [Re: RoryTek] #941471 08/19/09 06:59 PM
KB2IAW Offline
Interesting Read ...First time i saw a two way transmission i was aboard a destroyer ...i learned to read light before i could read code (1950`s ) first licenced in 1959 let it lapse 10 years later after getting married ...relicensed in 1986 ,still retain novice calls ...Great hobby ,not as active as i once was .I encourage every one to stick to it .NO CODE REQUIREMENTS FOR TECH . <img src="/forums/images/graemlins/patriot.gif" alt="" />
1994 montero SR 3.5 v6
City Of Hills Oneonta N.Y. FREEDOM HAS A TASTE,AND FOR THOSE THAT HAVE FOUGHT FOR IT, THE TASTE IS SO SWEET , THE PROTECTED WILL NEVER KNOW .
VENI VEDI DECI <oneontasportsmenclub.net>
Page 2 of 4 1 2 3 4
Moderated by  4x4Wire, Oyaji_Jon
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6431 MB (Peak: 0.7511 MB) Data Comp: Off Server Time: 2026-10-21 14:32:50 UTC
