Electric windows - not working
#941551
04/20/09 02:26 PM
Is there a quick fix to get one of the windows back up? Three out of four work. I just want to get the window up until I can work out what's wrong.
99 Auto Sportage. Wildcat Extractors, Lukey Turbo Muffler, Warn manual hubs, K&N Air filter, Tyres 30/9.5/15, Ironman 40mm springs, KYB front struts & rear shocks, GME TX3220 UHF radio, dual battery system. Twin 10" electric fans. Next Job: Body lift
Re: Electric windows - not working
[Re: BAZINGA]
#941552
04/21/09 03:52 AM
I had problems with the windows on my 99 for long time. The driver side and passager rear windows where only ones that would work. I finally just cut all the wires and took the Master switchs and took it apart and there was a bunch of Black stuff all over it like they spark and leave trails behind i cleaned it up and put it back to gather and works all of them like a champ... Too bad i cut all the windows wires. Only the masters job anyhow <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: Macneal]
#941553
04/21/09 06:46 AM
Yeh, it can be a pain in the neck, i have had to clean the contacts 3 times before. They are wearing down - I will need to get a replacement. I needed the quick fix so I could put the window up before it rained. Turns out I found one!!! You need to take the inside door panel panel off. Locate the electric motor. There will be a two wire lead coming from it. (blue and white if my memory is good). Connect them to a positive & negative source. I used jumper leads straight off the battery. It will either go up or down. Switch the leads and it will go the other way. Don't leave the connection on any longer than necessary, it may short something out. <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: BAZINGA]
#941554
04/21/09 05:20 PM
werd,
Please tell me that you at least included a fuse in your quick-fix and keep your jumpers wires covered when not in use. You'd be better off hardwiring in a new switch.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD. GONE, all I have left are a few spare parts and the wheels.
[Re: Dryver]
#941555
04/21/09 05:47 PM
Well, I did say it was a quick fix. <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: BAZINGA]
#941556
05/05/09 12:31 PM
same happend with my 2 out of 4 work and i had to disconect the wires in 2 doors so no one would put them down aha
[Re: fatty_791]
#941557
05/05/09 10:27 PM
My driver side window just dropped one day. Placed it up with 2 school erasers (propped between the glass and the metal frame). Eventually had to do the regulator like 100 dollars.... Also My rear passenger window did not work unless i locked the windows from the master control and i could finally operate it....... long story short it ended up being my ignition harness causing the rear windows to short out (it was traced to that)....as well as a faulty regulator web pageGOOD LUCK! <img src="/forums/images/graemlins/kewl.gif" alt="" />
