Fill/Drain front dif #941628 04/21/09 02:55 AM
ChrisB Offline OP
I was looking at my front dif and cant figure out how to fill or drain it.Can someone help me out.
01 Kia sportage,Removed front bumper,Warn manual hubs,
Soon To Come.Cb,4"lift,31's,Custom front bumper,Rock sliders,Winch,Roof rack,Hitch
Make it Break it
Re: Fill/Drain front dif [Re: ChrisB] #941629 04/22/09 02:19 AM
ChrisB Offline OP
Anyone at all..helloo
Make it Break it
Re: Fill/Drain front dif [Re: ChrisB] #941630 04/22/09 03:39 AM
Iron Offline
Can't remember 100% for sure, but there should be a fill plug on the backside of the diff, fill until comes out the hoke. As for draining! Crack the bolts, let it flow! BTW! your going to need a new seal!
08' Jeep Wrangler
64' Plymouth Sport Fury 383
58' Triumph TR-3A
Re: Fill/Drain front dif [Re: ChrisB] #941631 04/22/09 05:02 AM
DennisThompson Offline
There is a drain plug on the bottom of the dif, in the front facing fowward. The fill is on I believe the right side of the dif about 1/2 way up.
Hope tht helps, Dennis
Re: Fill/Drain front dif [Re: ChrisB] #941632 04/22/09 06:09 AM
bombardj1 Offline
to fill buy a gear oil pump it should screw into the bottle of gear oil just put the the tube into the filler hole and pump away.
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: Fill/Drain front dif [Re: bombardj1] #941633 04/22/09 02:38 PM
ChrisB Offline OP
i didnt see a fill or drain plug when i was under it
Make it Break it
Re: Fill/Drain front dif [Re: ChrisB] #941634 04/22/09 06:05 PM
bombardj1 Offline
both the fill and drain plugs are on the side of the halfshaft, the drain plug is not on the bottom of the diff. both are facing the front of the truck, look for them, the sway bar and other steering stuff could be in the way so you don't see them, thats why to fill you need a pump. remove the spash gaurd you should be able to see them and get to them.
Re: Fill/Drain front dif [Re: ChrisB] #941635 04/22/09 06:20 PM
bombardj1 Offline
did you try the kiatechinfo site to show you ? if not, sign up for it it's free it will help show the both plugs.
PHP: 7.4.33 Page Time: 3.056s Queries: 15 (0.003s) Memory: 0.6213 MB (Peak: 0.6986 MB) Data Comp: Off Server Time: 2026-06-13 13:16:49 UTC
