Got propane? #941830 04/21/09 09:17 PM
G
GUNIT Offline OP
Just called Gotpropane.com He wanted me to send carb gasket so he can see if he has one that would work.
I was wondering if some one could actually trace on a piece of paper the gasket and scan and email me it? Its on the 89 Raider 2.6 The Email is smrover1@aol.com
89 Raider 2.6 with 32x9.50 Tsl Bias on stock rims turned inside out. Yota shackles in rear front T bars cranked no sway bar,ditched reed valve and capped with quarter
Re: Got propane? [Re: GUNIT] #941831 04/21/09 09:42 PM
I live near their shop i could just dorp off a manifold.
Re: Got propane? [Re: TOASTY] #941832 04/21/09 09:46 PM
G
GUNIT Offline OP
That would be great if you could. I just called them just a couple hours ago. I really would love to finally climb hills without spitting and sputtering
Re: Got propane? [Re: GUNIT] #941833 04/21/09 10:20 PM
Kevin C Offline
How about a Starion EFI setup?
Salvage yards parts and no carb.
Kevin
Re: Got propane? [Re: Kevin C] #941834 04/21/09 10:51 PM
G
GUNIT Offline OP
The starion swap is good I just think the propane swap would suit me better. My Raider is pretty much offroad use only. I think I would rather run on propane than gas. Plus I would hate to run to junkyards trying to find good parts.
hopefully toasty can drop off manifold if not I will buy gasket and send to got propane.
Re: Got propane? [Re: GUNIT] #941835 04/22/09 01:30 PM
raiderquest Offline
sent PM
Re: Got propane? [Re: raiderquest] #941836 04/22/09 03:55 PM
What manifold are you running there are like 3
different types on the 2.6, It might not matter since they'll probably use the weber adapter anyways. the manifold i have has the EGR stuff.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6139 MB (Peak: 0.6916 MB) Data Comp: Off Server Time: 2026-06-07 08:31:21 UTC
