Page 2 of 3 1 2 3
Re: Montero update. [Re: StockRaider] #942314 04/27/09 03:30 AM
FrankR Offline
Per TSB-92-11-003 dated July 1992, head bolt torque should be 80 lb-ft hot or cold, with lightly oiled (30W) bolt threads, washers and underside of the bolt heads. No re-torque is necessary.
Frank
Re: Montero update. [Re: StockRaider] #942315 04/27/09 04:36 AM
I need to order a power steering pump. Rxinhed? <img src="/forums/images/graemlins/smile.gif" alt="" />
PM'd you. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Montero update. [Re: StockRaider] #942316 04/27/09 01:41 PM
87Montero Offline
Only problem here Scorpion, is the Harmonic Balancer is actually the crank belt pulley. Its pretty much a gotta do it thing. Besides, I like my AC and power steering. that reminds me, I need to order a power steering pump. Rxinhed? <img src="/forums/images/graemlins/smile.gif" alt="" />
Take a look in the back of the old turbo truck, there's a low miles starion pump back there somewhere I think.. Last I looked they seemed pretty similar..
Re: Montero update. [Re: rxinhed] #942317 04/27/09 01:42 PM
Mad_Scientist Offline
Looking great Richard <img src="/forums/images/graemlins/kewl.gif" alt="" /> The feeling of driving an engine you built yourself will be a good one I'm sure. I plan to experience that some day <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Montero update. [Re: Mad_Scientist] #942318 04/27/09 06:08 PM
StockRaider Offline OP
I really hope so, This engine has been such a thorn in my side since I bought the Montero. I am starting to consider selling it for an SR if all goes well. Shhhhhh don't tell the Montero I said that, it knows when I talk bad about it. <img src="/forums/images/graemlins/ignore.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Montero update. [Re: StockRaider] #942319 04/29/09 03:17 PM
87Montero Offline
I think that truck is possessed, it was the transmission when I owned it.. and when we fixed the bottom end, the top end went on you.. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Front axle, rear axle, transmission, engine... what's left to fix on her? The cancer spots <img src="/forums/images/graemlins/frown.gif" alt="" /> at least the interior is good in it!
Re: Montero update. [Re: 87Montero] #942320 04/29/09 11:58 PM
Only thing left to break on it is the frame and body. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Montero update. [Re: StockRaider] #942321 05/01/09 09:09 AM
I picked up a new water pump and T belt today er well yesterday. I also cleaned and oiled up most of my HLAs, anyone have advice on how to get the stuck ones out? Pliers don't seem to work <img src="/forums/images/graemlins/confused.gif" alt="" />. I should be making alot of progress this weekend. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Montero update. [Re: StockRaider] #942322 05/01/09 02:43 PM
Are you wedged in there? Would a strong magnet work? If they're not wedged and just stuck with goop may be soaking the rocker assembly in diesel would free them up <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Montero update. [Re: Mad_Scientist] #942323 05/07/09 03:19 AM
I got my stuck lash adjusters out. I had to set them in a vice and pry on the arm with a flat head. Not something I would recommend, but at $20 a pop per HLA I am taking the chance. I installed my water pump and timing belt tonight. I still have the valve covers to paint but after that the engine is finished. All I have to wait on is my new motor mount to get shipped here (scheduled delivery is the 13th)So I figure I will have the engine in the truck on the 14th or 15th if all goes well. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1983 Honda XL600R
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6457 MB (Peak: 0.7552 MB) Data Comp: Off Server Time: 2026-07-15 00:21:59 UTC
