Front Wheel Bearing #942478 04/27/09 06:37 PM
HarleyJohn Offline OP
I've gone and confused myself so I'm looking for a little help.
The left front wheel bearings on my daughter's '98 4WD 5-speed had some play in it. Having perused the forum I'm aware that sometime this just means the spindle nut isn't torqued correctly. So I figured I'd pull, inspect, re-grease and (assuming the bearings were in good shape) re-install the bearings. So I get all the way to the point that I've used the Ford spindle nut socket (with 2 of the teeth ground off) to remove the spindle nut. The hub assembly will not come off the shaft. In addition, the spline shaft that the locking hub mates to has about 1/4" up and down play in it (is this normal?). It appears I should just be able to pull the brake rotor and the hub should slide off the shaft. Unable to pull the spindle off the shaft, I tightened up the spindle nut/plate so that the wheel spun freely, but that there was no play in the bearing and bolted everything back together.
So what am I missing? Once the spindle nut/lock plate has been unscrewed off the shaft, what would keep the wheel hub from just sliding off the shaft?
Thanks for your guidance.
Re: Front Wheel Bearing [Re: HarleyJohn] #942479 04/27/09 07:00 PM
k120189 Offline
did u remove the c clip under the hub?
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: Front Wheel Bearing [Re: k120189] #942480 04/27/09 09:04 PM
Yes, I removed the C-clip. I essentially followed the below steps (which I cut and pasted from another thread)
1- go buy a spindle nut socket for an 80-96 fullsize bronco/f-150 and grind or break 2 opposing teeth off, leaving the other 2 opposing teeth
2- remove hubs, loosen front lug nuts, jack front suspension off the ground
3- remove wheels, remove spindle nut lock washer, remove spindle nut(s)
4- pull hub assembly off, bringing with it the outer wheel bearing. the inner bearing should stay on the spindle if there is enough grease holding it there. it can then be removed, sometimes, with a little prying at the race (be sure not to damage the spindle here).
So why does the hub not come off, and is the fact I can move the spline shaft up and down in the hub normal? I'd think the bearing race would keep the shaft from moving.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5935 MB (Peak: 0.6472 MB) Data Comp: Off Server Time: 2026-06-07 12:52:05 UTC
