Ball joint spacers?
#942565
04/28/09 06:09 AM
Few of my friends have done this on the Toyota's and asked me if we can do it to ours. Is there any reason we can't?
92 Galant vr4 11.17at132mph 98 Montero 2.5"lift,33/10.50/15,15x8procomp wheels. trail-gear rock sliders,ARB front bumper,Warn m8000 winch. Piaa lights.
Re: Ball joint spacers?
[Re: Brianawd]
#942566
04/28/09 11:55 AM
There are kits over in OZ for the upper joint. No reason you can't drop yours to the bottom of the arm.
[Re: OldColt]
#942567
04/28/09 03:58 PM
Well, there is a reason. Dropping ball joint under arm you going from uber-strong setup, practically bomb prof, to fairly marginal. If you plan to do anything serious with you truck I would be pretty cautious. Street cruising is OK. Otherwise you open up to potentially ripping ball joint off upper arm and/or CV popping out of hub or differential. I've seen both happen. First one is definitely more disastrous.
92 SR, 285/75R16 Yoko MT ARB locker GAST compressor AirLift 1000 MM10500 Snorkel custom rear bumper 02 Montero LS died protecting the master 08 PowerWagon (stock!)
[Re: Alex Kogan]
#942568
04/29/09 06:35 AM
hi there this is from new zealand i have a 91 swb 2.5tdi on 33 40mm lift plus many more mods i have done a ball joint flip as we say which entails removing the top ball joint and putting a spacer between it and the top A arm this puts the ball joint below instead of no top no problems at all and i go ultra hard my main problem is breaking rear trailing arm cheers TC
swb 2.5tdi 33" muds-50mm body lift-40mm OME rear coils-2.5"exhuast-ball joint flip-snorkel-unifilter air cleaner-added bonnet scoop for intercooler-ARB rear locker
PHP: 7.4.33 Page Time: 5.634s Queries: 15 (0.003s) Memory: 0.6023 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-06-09 23:10:36 UTCValid HTML 5 and Valid CSS
