22re Engine Codes 2 and 5 #943081 05/01/09 03:17 AM
Jake97T Offline OP
Replaced the oxygen sensor, connections for AFM are clean, havent cleaned the sensor itself if that can be done, any suggestions to eliminate?
Just bought it 3 weeks ago and need to do emissions to transfer title. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 22re Engine Codes 2 and 5 [Re: Jake97T] #943082 05/01/09 07:17 AM
4Crawler Offline
Have you cleared the codes and see if they return when the engine runs? Have you tested the ECU connections where those signals come back to see if they are actually reaching the ECU?
Re: 22re Engine Codes 2 and 5 [Re: 4Crawler] #943083 05/01/09 07:30 AM
Jake97T Offline OP
Cleared the codes, havent tested them at the ECU, still looking for info on that.
Re: 22re Engine Codes 2 and 5 [Re: Jake97T] #943084 05/01/09 03:42 PM
4Crawler Offline
The Factory Service Manual would have information on that. I have some ECU pin-out information below:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml#Troubleshooting
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6033 MB (Peak: 0.6588 MB) Data Comp: Off Server Time: 2026-05-25 16:01:26 UTC
