Page 2 of 26 1 2 3 4 25 26
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945001 05/15/09 04:16 PM
ghostraider Offline
it was easier to disconnect the manifolds...lift out the engine.....and then use all that space in the engine compartment to sit in and work on the exhaust..( which was soooo rusted!)
Re: My Pajero 3.0 V6 rebuild - with pics [Re: ghostraider] #945002 05/18/09 09:02 AM
4ePikanini Offline OP
got some more work done
- took the air filter housing out to give some space
- took the battery tray out for some space
- got the PS pump out of the way
- alternator removed (looks like the bracket will only come off after i have removed the cam sprocket)
TO DO LIST
-exhaust manifolds
-inlet ports with fuel rail
-rear water pipes
-tranny
-engine mountings
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945003 05/18/09 05:46 PM
TO DO LIST
-exhaust manifolds - CHECK - all bolts loosened and downpipe sprayed
-inlet ports with fuel rail - CHECK
-rear water pipes - HALFWAY CHECK
-tranny - NOT SURE WHERE TO START
-engine mountings - LAST ON THE LIST
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945004 05/19/09 09:57 AM
I have searched extensively but can't find a writeup on the removal steps of the tranny to engine
Anybody got a schematic of which bolts to remove. I don't want to struggle with bolts that are unnecessary.
Any hints and tips to make it easier?
Just want to have some idea before i go underneath there.
TIA
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945005 05/19/09 09:59 AM
I'll put up some pics today or tomorrow because I know it's not nice following a thread without a pics. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945006 05/19/09 03:58 PM
ghostraider Offline
I do not think there is any way to make it easier...if you are going to remove the engine or tranny then you Must remove all tranny to engine bolts as well as starter.
pretty mush everything under there
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945007 05/19/09 04:50 PM
4ePajero Offline
Why not ask your dad?
<img src="/forums/images/graemlins/smile.gif" alt="" />
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePajero] #945008 05/19/09 06:12 PM
a hundred heads are better than 2. <img src="/forums/images/graemlins/cheers.gif" alt="" />
got the manifolds disconnected from the downpipes. It looks like its just the starter, tranny and engine mountings left before I can do the pull. I should start looking at places to rent an engine hoist towards the end of the month.
Pics as promised <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945009 05/21/09 11:54 AM
I was reading here with regards to the EGR
http://www.mdocuk.co.uk/forums/viewtopic.php?t=15394
The thing is though that mine connects directly with a pipe from the outlet to the inlet without any valves. I thought about blocking off the holes but this seems to be a bad idea for power and economy.
My pipe has a crack in it so needs to be fixed/replaced.
I would just like some feedback on the technical aspects of why this helps the motor.
Thanks.
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945010 05/21/09 01:21 PM
FrankR Offline
The last time I checked, the pipe was no longer available from Mitsubishi. However, they sometimes will put parts back into production, so a check with the dealer will give you a current answer. Otherwise, if you want/need to keep the EGR system active, you will need to find a used one or make one from copper tubing - it's not so hard to do and it will work fine.
It does a few things to help the engine and fuel economy, but to a minor degree...... the main purpose is to reduce NOx emissions at cruise throttle. It works by reducing the combustion temperature of the fuel/air mixture through a dilution of the inlet air oxygen content and by slowing flame propagation - which results in a cooler combustion temperature:
web page
If you're not bound by emissions laws and inspections, you can eliminate the EGR system entirely, block off the openings for the valve and pipe and plug the vacuum ports for the thermo switch and EGR solenoid. If you go that route, you may find you need to raise spark lead slightly for best engine performance, but be careful you don't go too far and cause detonation under load.... an unlikely event in a Gen1 3.0L, but something to be aware of that could happen.
Frank
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6566 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-07-17 07:48:24 UTC
