Page 5 of 26 1 2 3 4 5 6 7 25 26
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945031 06/24/09 08:28 PM
4ePikanini Offline OP
I am waiting for my engine to get back from the rebuilders
In the meantime I'm tackling electrics and at the moment I want to get the 4x4 lights in the dash to work.
The rear wheels light ( green ) is not working but I traced that to a blown bulb.
The vacuum operated front diff system works
The only thing now is to get all 4 green lights to light up when I select either 4H, 4HLc, or 4LLc
I have followed the manual I got from SimonB ( thanks again )
and here are my results
Unfortunately there is no instruction or reference of how to remedy this or where it actually goes to or comes from. Anybody with some experience on this ( I believe this is a pretty common thing ) <img src="/forums/images/graemlins/confused.gif" alt="" />
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945032 06/24/09 10:15 PM
PartyTruck Offline
There are switches all over the T-case to indicate where it's positioned. Someone said 11 switches in total to me once with the backup light switch. They all seem to be alike but have either N/O or N/C operation. I'm guessing your 4lo switch is out and not feeding voltage to the control unit.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: My Pajero 3.0 V6 rebuild - with pics [Re: PartyTruck] #945033 06/25/09 06:30 AM
I have removed them all and tested their operation. They all work as intended ( they ground the circuit - not relay voltage )
Maybe they don't work on the transfer case itself.
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945034 06/25/09 07:23 AM
the bottom bulb is blown ( 2WD )
but the top one is not blown as it flickers sometimes when shifting between 4HLc and 4LLc
Originally Posted by rockett
Someone posted somewhere that the switches in the transfer and gearbox and diffs can become a bit worn down after a while so the correct signal is not always sent so that the correct lights are lit.
The fix was thinner washers. I have no idea where these switches are located. If that can be posted, then that can be traced and checked as well.
This ( thinner washers ) sounds like a good test because it flickers sometimes when switching between 4HLc and 4LLc
Maybe they don't work on the transfer case itself. I need to try that thinner washers thing.
Anybody with a picture from the top of the transfer case with the switches labeled?
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945035 06/25/09 04:39 PM
These are my findings
NOTE :
I have not commented on the rear wheel green lights as
1. My bulb is blown
2. They should be permanently on with the ignition so they never change
First picture courtesy of 4ePajero
Hence my trouble is obviously with number 5
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945036 07/12/09 06:55 PM
Success. <img src="/forums/images/graemlins/smile.gif" alt="" />
My lights are working the way they should except for the rear wheels (of which I presume the bulb is blown)
The rear wheels bulb I'll check out this week and replace or re-wire as necessary.
The dash is back in but I realised that only one speaker is wired. <img src="/forums/images/graemlins/evil.gif" alt="" /> ( That is gonna be another headache chasing cables )
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945037 07/20/09 01:41 PM
Updates
I fixed the dash lights and made a DIY about it here
- http://www.4x4wire.com/forums/showf...&an=0&page=1#Post1166466
I have also had word that the engine is stripped and almost clean.
I will go and have a look tomorrow afternoon and take my camera with.
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945038 07/20/09 05:52 PM
Grasscat Offline
Good job Marius. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Keep up the good work, your Monty will reward you.
Michael j
TreadLightly! Trainer
Re: My Pajero 3.0 V6 rebuild - with pics [Re: Grasscat] #945039 07/20/09 05:59 PM
87Montero Offline
Good job, I miss my Gen 2..
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 87Montero] #945040 07/21/09 05:07 PM
stripped
It is not as bad I initially feared but it is clear that the previous owner did no maintenance for over 50k.
The bores are slightly scored but if you look carefully you can still see the original honing marks after 250k <img src="/forums/images/graemlins/kewl.gif" alt="" />
The crank is slightly scored - due to lack of decent oil and VERY old oil - the workshop reckons it is 60k overdue for a change <img src="/forums/images/graemlins/scared.gif" alt="" />
Good news is that a bore ( with new pistons ) won't be necessary - just a good re-hone
I'll let the pictures speak further
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.011s) Memory: 0.6593 MB (Peak: 0.7667 MB) Data Comp: Off Server Time: 2026-07-17 07:50:09 UTC
