Page 6 of 26 1 2 4 5 6 7 8 25 26
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945041 07/21/09 09:40 PM
FrankR Offline
Good news is that a bore ( with new pistons ) won't be necessary - just a good re-hone
You might want a second opinion. The bores might LOOK ok, but if you run a dial indicator up and down, I'll bet you find the bores egg-shaped, with more wear in the middle-to-bottom third of the bore..... which will likely call for an over-bore.
From what I can see in the pictures, the crankshaft journals should polish ok.
Frank
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945042 07/21/09 11:46 PM
Talk to me before you bolt on the lower and upper intakes...
Re: My Pajero 3.0 V6 rebuild - with pics [Re: fasteddy] #945043 07/22/09 06:35 AM
4ePikanini Offline OP
May I ask why?
just watch this thread as it will be kept up to date and then just PM me when the time comes. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: My Pajero 3.0 V6 rebuild - with pics [Re: FrankR] #945044 07/22/09 06:38 AM
Frank
Thanks Frank
I'll remember when the workshop gives me their opinion as I just made my own uneducated decision <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945045 07/22/09 07:05 AM
May I ask why?
FE is one of the sage's (among quite a few) on this forum. I'm sure he has some good insight for you when you're ready to do that. I'd contact him when it came time to do that if it were me. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: My Pajero 3.0 V6 rebuild - with pics [Re: off-roader] #945046 07/22/09 07:28 AM
'FE is one of the sage's'
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945047 07/22/09 07:37 AM
FE = FastEddy. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: My Pajero 3.0 V6 rebuild - with pics [Re: off-roader] #945048 07/22/09 07:52 AM
Is there anything with regards to those intakes that I should observe other than making sure the surfaces are clean & flat, new gaskets and correct torques ?
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945049 07/22/09 11:25 AM
FrankR Offline
I don't know what Eddy will 'splain, but the lower intake has a habit of warping up on the ends to form a bowed surface. A good machinist can mill it flat.
Also, over time, coolant can etch the lower intake around the coolant passages and create leaks - milling usually resolves that as well.
Before installing the MLS gaskets between the lower intake and heads, I put 2 coats of Permatex Copper Spray-A-Gasket on the head flanges, intake flanges and both sides of the gaskets.
Frank
Re: My Pajero 3.0 V6 rebuild - with pics [Re: FrankR] #945050 07/22/09 12:00 PM
Thanks Frank
My offer stands for the <img src="/forums/images/graemlins/cheers.gif" alt="" /> and BBQ if you ever visit SA!
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6583 MB (Peak: 0.7640 MB) Data Comp: Off Server Time: 2026-07-17 07:50:13 UTC
