Page 9 of 26 1 2 7 8 9 10 11 25 26
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945071 08/14/09 07:22 AM
4ePikanini Offline OP
Small progress.
Engine will be back in two weeks.
In the meantime I've chased all the wires from the speakers as only the rear right was working.
All 4 speakers are working now and the wiring ball sorted behind the radio.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945072 08/15/09 09:04 AM
progress
before
after
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945073 08/15/09 11:36 AM
4ePajero:
Did you open it to check the
* brushes
* bearings/bushes
Was planning on doing it later but .... procrastination is not the way to go with a rebuild
Opened up and it looks good. No excessive wear after 257'000km
* I think mitsubishi engineers should get noble prizes for their simple robust designs
* I have yet to encounter a part on the pajero that is not easy to understand, take apart and/or service ( compared to the jetta where most things are a pain )
After opening and wiping
Points where I applied some copper grease before reassembly
Brushes close up
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945074 08/15/09 12:56 PM
I also had a supervisor making sure I do work.....
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945075 08/15/09 05:26 PM
Kevin C Offline
I would re-think putting grease on the sides of the brushes. Any contamination to the commutator will reduce the motors output.
Once brushes are contaminated with oil (thatÆs what is in the grease) it cant be removed.
What is on the sides will migrate.
Kevin
Re: My Pajero 3.0 V6 rebuild - with pics [Re: Kevin C] #945076 08/16/09 08:07 PM
Thanks Kevin
I'll strip again and clean - I haven't used the starter yet so I should be OK.
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945077 08/17/09 09:05 AM
My parts have arrived at the dealership and I'll pick them up today or tomorrow.
I'm not sure why I got two bolts for the crank ???
prices excludes vat at 14%
At time of posting -- R8.17682 = $1.00 - <a href="www.xe.com" target="_blank">www.xe.com</a>
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945078 08/17/09 04:36 PM
still waiting for one hose
haven't checked the parts to the originals yet...
dealer sent me two crank bolts as they don't know which one it is even though I sent them a pic of the car,
engine, vin plate and manufacturing plate ??? any ideas?
anyways here are some of the parts
[img]http://img220.imageshack.us/img220/622/thermostatbypasshose.jpg[/img]
[img]http://img205.imageshack.us/img205/6685/thermostat.jpg[/img]
[img]http://img182.imageshack.us/img182/3852/tobearing.jpg[/img]
[img]http://img21.imageshack.us/img21/1230/upperradhosez.jpg[/img]
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945079 08/17/09 06:31 PM
Neither of those bolts look like what I call the "crank bolt" and as it looks from my 95. Mine has the long neck tha come though the balancer.
Here a link to a past thread that has pics of the old bad on and the new one the recall replaces with. (My 95 had the new as it was post-recall.)
Past crank bolt thread
Re: My Pajero 3.0 V6 rebuild - with pics [Re: MontyMcV] #945080 08/17/09 08:44 PM
old well known bolts
bolts I bought from dealer
That was my initial thought as well but reading that thread this post makes me wonder ..... <img src="/forums/images/graemlins/confused.gif" alt="" />
KrzyDav - #1108543 - 08/07/24 11:42 PM
I recently ordered a Crank bolt from ..parts.com (i think) Korum Mitsu in WA. The improved bolt has been superceded by what looks like a hardened vertion of the caravan bolt.
It's short but installs just fine with a standard 6" extention.
FastEddy...... is there any way you could post a pic of this washer?
FastEddy - #1108550 - 08/07/24 11:42 PM
The washer should be a belleville type, with a slight dome which goes toward the bolt head. This puts a "spring" tension on the pulley at proper torque.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.011s) Memory: 0.6626 MB (Peak: 0.7884 MB) Data Comp: Off Server Time: 2026-07-17 07:42:23 UTC
