Page 11 of 26 1 2 9 10 11 12 13 25 26
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945091 08/23/09 12:27 PM
4ePikanini Offline OP
I went looking for lenses for my hella spotlights ( as they were badly cracked and chipped ) but.........
There was an enthusiastic salesman that said I can get brand new spots plus globes at half the price of the hella lenses
So I bought two pairs <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
wiring done as follows
if (brights = ''on'') and (dash switch = ''on'') then (spots = ''on'')
else
(spots = ''off'')
Running through a 30 Amp relay with 600watt lawnmower wiring and a 20 amp fuse
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945092 08/25/09 07:55 AM
Eish. Camera took a dump so no pictures for a while.
replaced the back 12v socket and the TO bearing last night
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945093 08/25/09 12:17 PM
I got warned about the wire gauge so I went investigating
Silly me. I knew I must have given the wrong info somewhere because my wires aren't getting hot ( not even at the connectors ) . I went and traced the invoice ( 18 months ago from online incentive program ) and found that the wire I bought was rated at 2500 Watts. ( and probably have a bit extra for safety )
So
2500W/240V = 10.4A
I doubled up the wire so that should give me just more than 20 Amps which is enough for the spots ( 220W/12V = 18.3A ).
Am I correct in my reasoning here?
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945094 08/25/09 02:47 PM
FrankR Offline
Almost. What you're missing is the length of run. The longer the wire, the greater the resistance and subsequently, the greater the voltage drop across the run.
So, if you can post the wattage of the lights, the size of the wire AND the length of run from the battery to the lights, then someone can check your choice of wire size.
Frank
Re: My Pajero 3.0 V6 rebuild - with pics [Re: FrankR] #945095 08/25/09 02:49 PM
4x 55 watt spots
2500watt ( 220v ) rated wire which I doubled up
length is probably around 1.3m - took the shortest route from the battery to the spots.
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945096 08/25/09 03:28 PM
got a picture taken with another camera
this is the wiring on an iso measuring tape ( millimeters )
I used both wires twisted together for the positive feed to the spots.
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945097 08/25/09 04:28 PM
FrankR Offline
You'll have to tell us what size the wire is in wire gauge size:
Calculator
Frank
Re: My Pajero 3.0 V6 rebuild - with pics [Re: FrankR] #945098 08/25/09 07:06 PM
My money is on 14ga, just looking at it.
The fatter the wire, the lower the voltage drop, and the cooler the wire runs.
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945099 08/25/09 07:20 PM
Mad_Scientist Offline
A thing of beauty...a tape measure with only cm and mm on it. Stuff that dreams are made of <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: My Pajero 3.0 V6 rebuild - with pics [Re: Mad_Scientist] #945100 08/26/09 07:21 AM
I couldn't find the gauge but on the wire it says
15A/25m MAX
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6573 MB (Peak: 0.7634 MB) Data Comp: Off Server Time: 2026-07-17 03:44:51 UTC
