Page 16 of 26 1 2 14 15 16 17 18 25 26
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945141 09/08/09 11:37 AM
FrankR Offline
Some things can be done out of sequence, but I find it best to follow this order:
1) Front covers
2) Cooling fan bracket
3) A/C compressor bracket
4) A/C compressor
5) Serpentine belt tensioner bracket
6) P/S mounting bracket
7) P/S pump bracket
8) P/S pump
9) Radiator
10) Lower shroud
11) Engine cooling fan
12) Upper shroud
13) Radiator hoses
14) Drive belts
15) Alternator
16) Coil
Don't forget the transmission cooling lines if you have an automatic.
Frank
Re: My Pajero 3.0 V6 rebuild - with pics [Re: FrankR] #945142 09/08/09 11:53 AM
4ePikanini Offline OP
Thank you so much. Should be able to get all of that done tonight.
I don't have an automatic but I have the oil cooler for the engine.
My shroud is a one piece so I'll just improvise on that one.
Thanks again.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945143 09/08/09 03:56 PM
MBrannon Offline
cambelt covers
a/c compressor
ps pump
alternator
spark plug wires
coil bracket
belts
radiator and lower cowling
fan
upper cowling
MAS and intake tube
cruise control/throttle cable
That should get you going...
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: My Pajero 3.0 V6 rebuild - with pics [Re: MBrannon] #945144 09/08/09 04:33 PM
I aligned the dizzy like this before dropping it in. is it correct?
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945145 09/08/09 06:05 PM
FrankR Offline
That's the factory suggested method, but you can never be sure about a distributor setting unless you know where the rotor should point at TDC. Try it this way:
Put the engine on TDC (compression stroke). You can do that a couple of ways:
1) With the spark plugs removed, rotate the engine until you can feel air coming out of the #1 spark plug hole, then continue to rotate the engine until the crankshaft pulley timing mark comes up on TDC on the front cover mark.
- or -
2) With the driver side (on a LH driver) cam sprocket cover off, rotate the engine until the cam sprocket is aligned with the mark on the rear cover.
Then insert the distributor - the rotor should point to ~ the center of the firewall.
Frank
Re: My Pajero 3.0 V6 rebuild - with pics [Re: FrankR] #945146 09/08/09 06:31 PM
Thanks Frank.
All of that checks out. Going slow now as I hooked my knee cap between bumper and tow hitch twisting it about 45 degrees before popping out - it's killing me and slowly getting worse.
I'm jumping along on one leg but getting there.
still to do
A/C
PS pump
radiator + fan and cowling
fluids
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945147 09/08/09 09:05 PM
day end. got a lot done but with my knee cap pinched between bumper and tow hitch and twisting 45 i'm now on crutches. will see what tomorrow brings
need to do tomorrow
cowling
fluids
charge battery
double check as many bolts as I can find
follow Frank's start procedure
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945148 09/09/09 12:01 AM
MBrannon Offline
ouch! I just had knee surgery 6 weeks ago. Not fun at all <img src="/forums/images/graemlins/frown.gif" alt="" />
1998 Montero
2007 Prius
Re: My Pajero 3.0 V6 rebuild - with pics [Re: MBrannon] #945149 09/09/09 06:16 AM
can barely walk this morning, but happy with what I got done last night
As it stands now
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945150 09/09/09 06:47 AM
87Montero Offline
That looks tasty!
PHP: 7.4.33 Page Time: 0.012s Queries: 14 (0.009s) Memory: 0.6563 MB (Peak: 0.7614 MB) Data Comp: Off Server Time: 2026-07-17 02:01:35 UTC
