Page 17 of 26 1 2 15 16 17 18 19 25 26
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 87Montero] #945151 09/09/09 11:51 AM
4ePikanini Offline OP
With just about everything bolted on, I am proud to say I don't have any bolts lying around needing a home. smile
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945152 09/09/09 02:49 PM
hazy_daze Offline
Uh... it ain't never gunna work right without extree parts <img src="/forums/images/graemlins/smile.gif" alt="" />
Looks GREAT!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: My Pajero 3.0 V6 rebuild - with pics [Re: hazy_daze] #945153 09/09/09 02:56 PM
Uh... it'll ain't never gunna work right without extree parts <img src="/forums/images/graemlins/smile.gif" alt="" />
huh? I lost you there..... <img src="/forums/images/graemlins/confused.gif" alt="" />
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945154 09/09/09 04:31 PM
Mad_Scientist Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> That's great!
Re: My Pajero 3.0 V6 rebuild - with pics [Re: hazy_daze] #945155 09/09/09 07:16 PM
4ePajero Offline
Agreed!
One has to have left-over bolts, nuts and spring washers to populate the "nuts-n-bolts" bucket!
PS You don't have a spare dip stick lying around?
Don't ascribe to malice anything that can be adequately explained as stupidity!
Pajero LWB Gen1 3.2 Di-D TD Engine
33" Bridgestone D694s
2" Lift
Front Runner Rack
Re: My Pajero 3.0 V6 rebuild - with pics [Re: Mad_Scientist] #945156 09/09/09 07:19 PM
All buttoned up but I can't start it as I'm missing the dipstick. I'm hoping it's at the workshop.
On the other hand my knee is just about back to normal. I couldn't walk this morning and now I barely have a limp. weird....
And I did connect the loose ground ( can you spot it ? )- before you ask <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945157 09/09/09 07:30 PM
btw. when I start it tomorrow, what should the electrical advance be?
5 degrees btdc at idle?
Do i need to plug or bridge a connector before checking?
We have 95 octane here.
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945158 09/09/09 08:11 PM
FrankR Offline
Don't even try to set the ignition timing until after you've run the engine for the first 20 minutes at a high idle and changed the oil and coolant.
For the initial warmup, just set the distributor in the middle of the adjustment slot - it should be fine. You can move it around in the slot to find a better spot if it stumbles.
You don't ever want to try to set the ignition advance on a cold engine. When you do set it, be sure to ground the wire at the firewall and set it at 5? BTDC. Once the base timing is set, remove the ground wire and the lead should change to ~ 15? BTDC at idle.
Frank
Re: My Pajero 3.0 V6 rebuild - with pics [Re: FrankR] #945159 09/09/09 09:07 PM
Renegade Offline
Nice and clean. How did you get you intake manifold so clean looking. Did you paint it or polish it up.
87 Dodge Raider 4.3 Vortec work in progress
89 Dodge Raider 3.0 V6 Fully Restored
Links are in my Bio to Photos
Re: My Pajero 3.0 V6 rebuild - with pics [Re: FrankR] #945160 09/09/09 09:13 PM
the only two connectors I have on the firewall are these two.
Is it one of them?
PHP: 7.4.33 Page Time: 0.018s Queries: 16 (0.014s) Memory: 0.6554 MB (Peak: 0.7781 MB) Data Comp: Off Server Time: 2026-07-17 07:26:01 UTC
