Re: My Pajero 3.0 V6 rebuild - with pics
[Re: 87Montero]
#945151
09/09/09 11:51 AM
With just about everything bolted on, I am proud to say I don't have any bolts lying around needing a home.
 Karma's Law - For every action there is a multiplied reaction! 93 Pajero GLS 3.0 V6 LWB - SOLD 2001 Gen3 Di-D LWB - SOLD 2005 Touareg R5 2.5 TDi
[Re: 4ePikanini]
#945152
09/09/09 02:49 PM
Uh... it ain't never gunna work right without extree parts <img src="/forums/images/graemlins/smile.gif" alt="" />
Looks GREAT!!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: hazy_daze]
#945153
09/09/09 02:56 PM
Uh... it'll ain't never gunna work right without extree parts <img src="/forums/images/graemlins/smile.gif" alt="" /> huh? I lost you there..... <img src="/forums/images/graemlins/confused.gif" alt="" />
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: 4ePikanini]
#945154
09/09/09 04:31 PM
Uh... it'll ain't never gunna work right without extree parts <img src="/forums/images/graemlins/smile.gif" alt="" /> huh? I lost you there..... <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> That's great!
[Re: hazy_daze]
#945155
09/09/09 07:16 PM
Uh... it ain't never gunna work right without extree parts <img src="/forums/images/graemlins/smile.gif" alt="" /> Agreed! One has to have left-over bolts, nuts and spring washers to populate the "nuts-n-bolts" bucket! PS You don't have a spare dip stick lying around? <img src="/forums/images/graemlins/lol.gif" alt="" />
Don't ascribe to malice anything that can be adequately explained as stupidity! Pajero LWB Gen1 3.2 Di-D TD Engine 33" Bridgestone D694s 2" Lift Front Runner Rack
[Re: Mad_Scientist]
#945156
09/09/09 07:19 PM
All buttoned up but I can't start it as I'm missing the dipstick. I'm hoping it's at the workshop. On the other hand my knee is just about back to normal. I couldn't walk this morning and now I barely have a limp. weird.... And I did connect the loose ground ( can you spot it ? )- before you ask <img src="/forums/images/graemlins/wink.gif" alt="" /> ![[Linked Image]](http://img154.imageshack.us/img154/6166/1010213.jpg)
[Re: 4ePikanini]
#945157
09/09/09 07:30 PM
btw. when I start it tomorrow, what should the electrical advance be?
5 degrees btdc at idle?
Do i need to plug or bridge a connector before checking?
We have 95 octane here.
[Re: 4ePikanini]
#945158
09/09/09 08:11 PM
Don't even try to set the ignition timing until after you've run the engine for the first 20 minutes at a high idle and changed the oil and coolant.
For the initial warmup, just set the distributor in the middle of the adjustment slot - it should be fine. You can move it around in the slot to find a better spot if it stumbles.
You don't ever want to try to set the ignition advance on a cold engine. When you do set it, be sure to ground the wire at the firewall and set it at 5? BTDC. Once the base timing is set, remove the ground wire and the lead should change to ~ 15? BTDC at idle.
Frank
[Re: FrankR]
#945159
09/09/09 09:07 PM
Nice and clean. How did you get you intake manifold so clean looking. Did you paint it or polish it up.
87 Dodge Raider 4.3 Vortec work in progress 89 Dodge Raider 3.0 V6 Fully Restored Links are in my Bio to Photos
[Re: FrankR]
#945160
09/09/09 09:13 PM
the only two connectors I have on the firewall are these two. Is it one of them? ![[Linked Image]](http://img402.imageshack.us/img402/8017/1010216.jpg)
