Re: My Pajero 3.0 V6 rebuild - with pics
[Re: OldColt]
#945191
09/14/09 04:14 PM
I'd say colt's got it.. I had the same thing in my honda accord except much bigger. It took up the whole corner of the passenger front bumper.When removed, I insantly had a race car
1999 Mitsu Montero - Crappy Weather 1992 Isuzu Pickup - Zombie Apocalypse 2008 Saturn Sky Redline - Nice Weather
[Re: 87Montero]
#945192
09/15/09 12:40 AM
You can remove that without any ill effects. Just make sure you plug the hole well.
Your ECU may be bad with the idle issue.
1992 VR4 12.5 @ 110 - SOLD 1993 Stealth RT/TT 11.4 @ 129 - SOLD 1991 VR4 9.2 @ 159 - Old Shop Car 1992 Stealth Twin Turbo ATX - SOLD 1990 Montero LS LWB - RIP 1995 Montero LS - RIP 1998 Montero 1992 Galant VR4 474/1000 2007 Prius
[Re: OldColt]
#945193
09/15/09 01:18 AM
That makes a lot of sense, Charlie.
I make a bet that a usa spec maf will fit your engine. Pre obd2. Anybody want to help this guy out and send him one off a junker. Pretty small package and light, so should ship cheap. Might be a good idea to compare part #'s first.
This maf is a karmann vortex type, and the sensor uses ultrasonic waves to count the number of vortices in the intake air. Vortex generation/count is directly proportional to air mass flow rate. If the ultrasound sender or receiver windows are dirty, you can get a false air flow rate to the ecu. A careful reading of the fsm may get you a reading range for the maf outputs at idle and some higher rpms. I think there's a digital/analog converter on the maf pcb that converts vortex count to a varying voltage signal to the ecu.
[Re: fasteddy]
#945194
09/15/09 07:37 AM
I will foot the bill if you can find and ship one at a reasonable price. I will be forever grateful! This is the sticker on top of mine. ![[Linked Image]](http://img5.imageshack.us/img5/4729/maft.jpg)
 Karma's Law - For every action there is a multiplied reaction! 93 Pajero GLS 3.0 V6 LWB - SOLD 2001 Gen3 Di-D LWB - SOLD 2005 Touareg R5 2.5 TDi
[Re: 4ePikanini]
#945195
09/15/09 08:35 AM
Is this worth having a look at? http://cgi.ebay.com/ebaymotors/3000GT-DI...06.c0.m245#shId$37.50 USPS Priority Mail International shipping to South Africa
[Re: 4ePikanini]
#945196
09/15/09 06:53 PM
hold the phone......
did the clean and so far so good (touch wood). No more hunting. will let you know how she goes
to-do list
- check rear gate switch - it's causing a flickering dome light over bumps ( where is this switch? I've looked and not found ???) - replace bearing for viscous fan pulley - it's screeching <img src="/forums/images/graemlins/frown.gif" alt="" /> - front and rear diff oil change - gearbox and transfer case oil change - fix leak on gearbox side cover - change engine oil and filter - have A/C charged
[Re: 4ePikanini]
#945197
09/16/09 10:20 AM
I have a pulley squeel ( very intermittent ) and the only one it could be is this one as it still squeels with A/C belt and PS pump belt removed. ![[Linked Image]](http://img195.imageshack.us/img195/70/pulley.jpg) Do I need to buy it as a whole or can I have a bearing pressed in? Thanks
[Re: 4ePikanini]
#945198
09/16/09 10:32 AM
MD143208 Bracket Assy,cool $43.48
For the price its probably easier to just replace it.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#945199
09/16/09 10:34 AM
Also, did you replace your timing belt pulley? those wear out faster than most other pulleys I see.
[Re: StockRaider]
#945200
09/16/09 11:03 AM
Also, did you replace your timing belt pulley? those wear out faster than most other pulleys I see. yes. Brand new oem. This was the old one. had a close look at the cambelt tensioner and decided to order a new one LLMD166227 SPRING,VALVE TIMING BELT 34.27+vat LLMD104578 TENSIONER,VALVE TIMING BE 364.29+vat
