Page 21 of 26 1 2 19 20 21 22 23 25 26
Re: My Pajero 3.0 V6 rebuild - with pics [Re: OldColt] #945191 09/14/09 04:14 PM
87Montero Offline
I'd say colt's got it.. I had the same thing in my honda accord except much bigger. It took up the whole corner of the passenger front bumper.When removed, I insantly had a race car smile
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 87Montero] #945192 09/15/09 12:40 AM
MBrannon Offline
You can remove that without any ill effects. Just make sure you plug the hole well.
Your ECU may be bad with the idle issue.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: My Pajero 3.0 V6 rebuild - with pics [Re: OldColt] #945193 09/15/09 01:18 AM
That makes a lot of sense, Charlie.
I make a bet that a usa spec maf will fit your engine. Pre obd2. Anybody want to help this guy out and send him one off a junker. Pretty small package and light, so should ship cheap. Might be a good idea to compare part #'s first.
This maf is a karmann vortex type, and the sensor uses ultrasonic waves to count the number of vortices in the intake air. Vortex generation/count is directly proportional to air mass flow rate. If the ultrasound sender or receiver windows are dirty, you can get a false air flow rate to the ecu. A careful reading of the fsm may get you a reading range for the maf outputs at idle and some higher rpms. I think there's a digital/analog converter on the maf pcb that converts vortex count to a varying voltage signal to the ecu.
Re: My Pajero 3.0 V6 rebuild - with pics [Re: fasteddy] #945194 09/15/09 07:37 AM
4ePikanini Offline OP
I will foot the bill if you can find and ship one at a reasonable price. I will be forever grateful!
This is the sticker on top of mine.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945195 09/15/09 08:35 AM
Is this worth having a look at?
http://cgi.ebay.com/ebaymotors/3000GT-DI...06.c0.m245#shId
$37.50 USPS Priority Mail International shipping to South Africa
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945196 09/15/09 06:53 PM
hold the phone......
did the clean and so far so good (touch wood). No more hunting. will let you know how she goes
to-do list
- check rear gate switch - it's causing a flickering dome light over bumps ( where is this switch? I've looked and not found ???)
- replace bearing for viscous fan pulley - it's screeching <img src="/forums/images/graemlins/frown.gif" alt="" />
- front and rear diff oil change
- gearbox and transfer case oil change
- fix leak on gearbox side cover
- change engine oil and filter
- have A/C charged
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945197 09/16/09 10:20 AM
I have a pulley squeel ( very intermittent ) and the only one it could be is this one as it still squeels with A/C belt and PS pump belt removed.
Do I need to buy it as a whole or can I have a bearing pressed in?
Thanks
Re: My Pajero 3.0 V6 rebuild - with pics [Re: 4ePikanini] #945198 09/16/09 10:32 AM
StockRaider Offline
MD143208 Bracket Assy,cool $43.48
For the price its probably easier to just replace it.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: My Pajero 3.0 V6 rebuild - with pics [Re: StockRaider] #945199 09/16/09 10:34 AM
StockRaider Offline
Also, did you replace your timing belt pulley? those wear out faster than most other pulleys I see.
Richard E
1983 Honda XL600R
Re: My Pajero 3.0 V6 rebuild - with pics [Re: StockRaider] #945200 09/16/09 11:03 AM
yes. Brand new oem. This was the old one.
had a close look at the cambelt tensioner and decided to order a new one
LLMD166227 SPRING,VALVE TIMING BELT 34.27+vat
LLMD104578 TENSIONER,VALVE TIMING BE 364.29+vat
PHP: 7.4.33 Page Time: 2.593s Queries: 16 (0.012s) Memory: 0.6575 MB (Peak: 0.7787 MB) Data Comp: Off Server Time: 2026-07-17 07:42:28 UTC
