Re: Gen 3 REAR BUMPER Build **Pics**
[Re: icysyrup]
#945395
05/29/09 02:44 PM
The bumper looks really clean. Good work.
Are there any places on the bumper that can facilitate the use of a Hi-Lift Jack? Maybe the step on the side?
Guntero (died in battle) 1995 Montero LS - Matte Black 265/75R16 BFG All-Terrains
Guntero (current) 2001 Montero Limited - Gold OME HD Lift 285/75R16 BFG All-Terrains
[Re: Guntero]
#945396
06/01/09 09:36 PM
Thanks Hooch, I have not tested the side step yet. It is built out of 1/8" so should be plenty stout enough. The bumper on the rear could also be used to lift with the highlift on either side of the hitch. Once I have finish welded everything up I will test it and report back. <img src="/forums/images/graemlins/smile.gif" alt="" />
Phil
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
[Re: icysyrup]
#945397
06/15/09 09:35 PM
Anyone interested in these...post up. PM me for more details if needed.
[Re: icysyrup]
#945398
06/15/09 10:39 PM
Nice job man! how thick of steel did you use on that and did you just brake it all or cut and weld each panel? either way it looks great, almost factory
Where da mud at?
[Re: fastlayne]
#945399
07/13/09 05:27 PM
[Re: fastlayne]
#945400
07/13/09 06:40 PM
Nice job man! how thick of steel did you use on that and did you just brake it all or cut and weld each panel? either way it looks great, almost factory Its made out of 1/8" steel plate. The square tubing that was the foundation had 45 degree notches put in it so that we could bend it around and still get the nice radius bend under the tail lights. The panels ont he bottom are cut and welded and the one directly under the tail light is done with a break to get the nice round radius. The main mounts are 1/4" where the hitch reciever is and it mounts to the tow hitch points. Hope this helps Phil
[Re: icysyrup]
#945401
07/13/09 07:32 PM
Looks awesome <img src="/forums/images/graemlins/kewl.gif" alt="" /> I needed one of those on Saturday <img src="/forums/images/graemlins/scared.gif" alt="" /> (see URE thread)
[Re: icysyrup]
#945402
07/15/09 03:43 PM
That looks good man! Good ideas you got there. Wish we were neighbors, so we could also wheel too <img src="/forums/images/graemlins/kewl.gif" alt="" />
