Fuel Pump starts when?
#945437
05/14/09 06:17 PM
Should a fuel pump in a 1988 Trooper run briefly when the ignition is in the ON position or does it only run in the START position?
1988 Isuzu Trooper II 150,000 miles starting to have more replaced parts than original parts 2.6 L 4 cyl 4X4 Never say die!
Re: Fuel Pump starts when?
[Re: dayoldpoi]
#945438
05/14/09 07:59 PM
It runs briefly in the on position in order to pressurize the system for the start.
[Re: Jim_Paget]
#945439
05/14/09 11:29 PM
Isuzu Moderator
I *think* that is true for the v6 engines. For the 2.6's, I think it only will run when you turn it to start. The system holds pressure (unlike the TBI systems) and in the 2.6, it won't run unless there is oil pressure and engine off, key on, should not give a signal to the pump to run. When the key is turned to start, it feeds battery voltage to the pump (system is already pressurized) and once the alt fires off, it then switches over to alt power.
Besides, the 2.6 fuel system is controlled by the fuel regulator, not the pump. If the pump turns on, it does not "know" when to turn off, excess fuel is just bypassed through the regulator. I suspect the TBI system may use the ECU to run the pump for a few seconds with the key in the on position.
Of course, this all started with I *think*.
Michael
[Re: mlclark]
#945440
05/15/09 12:09 AM
Michael most likely correct. american cars tend to run the pump for a second when the key is turned to on. the japanese typically dont run it until start position.
87 Montero V6 SWB auto. dual bouncies 89 Montero V6 SWB 5 speed. dual bouncies 97 3000gt VR4 upgraded turbos, 10:1, E85 91 Stealth TT twin 18Gs, cams/heads, E85 03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" /> 91 MR2 turbo
[Re: vr4]
#945441
05/15/09 03:57 AM
On 4 cyl., pump initially runs in start position (ign. switch through fuse 23 through non-energized fuel pump relay). When alternator produces voltage at White wire with Green stripe, the "engine" relay is energized and passes current to fuse 12, through the diodes, and then energizes the fuel pump relay. Fuse 24 then provides voltage through energized relay to fuel pump. Keep in mind this means you have to have working alternator to have good fuel pump operation.
[Re: HondaGuy]
#945442
05/21/09 05:05 PM
On 4 cyl., pump initially runs in start position (ign. switch through fuse 23 through non-energized fuel pump relay). When alternator produces voltage at White wire with Green stripe, the "engine" relay is energized and passes current to fuse 12, through the diodes, and then energizes the fuel pump relay. Fuse 24 then provides voltage through energized relay to fuel pump. Keep in mind this means you have to have working alternator to have good fuel pump operation. damn...where were you a few months ago <img src="/forums/images/graemlins/lol.gif" alt="" />
