drop dif kit #945900 05/19/09 06:06 AM
toyT100 Offline OP
Does anyone know who makes a front drop dif kit for T100's?
Re: drop dif kit [Re: toyT100] #945901 05/19/09 06:04 PM
G
Greg_Canada Offline
4crawler does, but they are not really necessary on the t100 suspension. How much lift are you running?
89 4Runner
Re: drop dif kit [Re: Greg_Canada] #945902 05/20/09 12:14 AM
toyT100 Offline OP
I have BJ spacers up front and nothing in back... im running 35's and the cv angles are too great I think.
Re: drop dif kit [Re: toyT100] #945903 05/20/09 01:13 AM
CJMT100 Offline
So crank the torsion bars down a wee bit..
Take a pic of said angles for us to see too, what you think is extreme maybe fine to us.
Re: drop dif kit [Re: CJMT100] #945904 05/21/09 02:12 AM
toyT100 Offline OP
Re: drop dif kit [Re: toyT100] #945905 05/21/09 03:50 PM
CJMT100 Offline
Ive seen worse, try lowering the torsions a bit first, if that doesnt work then I would do the diff drop kit.
Re: drop dif kit [Re: CJMT100] #945906 05/21/09 04:09 PM
toyT100 Offline OP
I already rub somewhat with the 35s now and would like to try and keep as much clearance up front. I plan on cranking down the bars though. Also Im not sure which drop dif kit from 4crawler will work for T100s. Does anyone know?
Re: drop dif kit [Re: toyT100] #945907 05/21/09 05:36 PM
G
Greg_Canada Offline
The one for teh 86-96 truck/4runner.
89 4Runner
Re: drop dif kit [Re: Greg_Canada] #945908 05/21/09 10:37 PM
toyT100 Offline OP
and that works for all years of the T100s?
Also should I get the sway bar drop kit?
Re: drop dif kit [Re: toyT100] #945909 05/22/09 02:33 AM
CJMT100 Offline
Yep, the T100 is nothing more than an oversized mini truck.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6337 MB (Peak: 0.7415 MB) Data Comp: Off Server Time: 2026-06-19 02:36:17 UTC
