Re: Diff Question [Re: jdavis] #946277 05/22/09 03:35 PM
The pinion should have no play, the bearings should run with a preload. Spinning will have a light drag.
If there is any play in that shaft no seal will hold the oil in. That diff could well be shot.
Re: Diff Question [Re: OldColt] #946278 05/22/09 04:14 PM
jdavis Offline OP
I'll have to check when I get home. But I remember there being a little up/down play and a fraction of in/out play. If that is the case, can the pinion bearing be replaced or would a complete rebuild be the recommend?
Thanks,
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: Diff Question [Re: jdavis] #946279 05/22/09 04:20 PM
Clearly the bearings can be replaced. The question is, why did they go bad? As well as, did the gears get damaged.
I doubt you can repair it for what you can buy a used one for.
Re: Diff Question [Re: jdavis] #946280 05/22/09 05:52 PM
Alex Kogan Offline
The picture is deceiving. While driving the oil leaks onto the driveshaft. The spin of the shaft is throwing most of the oil towards the drive side of the truck. I hear you about damaging the seals though. When I dropped it the second time, I noticed the passenger seal was damaged. Pretty sure, I caused that <img src="/forums/images/graemlins/frown.gif" alt="" /> Live and learn
Decieving or not buy you can see oil dripping off diff mount. CV is all covered too. There is no way you can get oil there from pinion seal. That's exactly the picture I saw when my driver's side half-shaft seal was leaking. New seal fixed that.
08 PowerWagon (stock!)
Re: Diff Question [Re: OldColt] #946281 05/26/09 09:10 PM
jdavis Offline OP
Did not mean to disappear. We went camping for the holiday weekend. Yea!! camping in my wife's Volvo. Man, I missed the Montero
I can only think of two reasons for the bearing to go bad. I swapped the rear end last year and the mark that to realign the driveshaft to the diff was wiped off. So, just reattached and off we went. Did not notice any new vibration afterwards.
The other would be on the day the leak started. We were out running up in the snow and I got stuck. It is hard to tell how deep the snow was but my wife could not get out on the passenger side. A couple hours after being pulled out I noticed the leak.
That was the second time getting stuck on that day. Gave the truck a good work out that day. I probably should have aired down.
Alex good observation - I'll double check the seal to make sure it is not leaking.
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6156 MB (Peak: 0.6813 MB) Data Comp: Off Server Time: 2026-06-09 21:58:18 UTC
