Page 3 of 6 1 2 3 4 5 6
Re: Gen 1 LockRite Group Buy [Re: LandRaider] #946801 06/01/09 08:59 PM
might as well just weld the rear diff if thats the case, I just can't imagine a lockrite costing less than the axle swap.
Re: Gen 1 LockRite Group Buy [Re: zarktheshark] #946802 06/02/09 12:05 AM
justice Offline
I'm trying to follow along, but think I got lost. I know what a lockrite is (had one in my YJ) and i know about the montero sport axel swap(via this site), but if i'm reading this thread right, the sport axel swap is the aussie locker? Note, my goal in the end is to have rear disk brakes and have an "on road" friendly locker in the rear which is why this thread is very interesting to me. I don't plan on doing much adding of power. I'm ok with going slow:)
The Sport axle swap is a selectable factory air locker. This swap is for 2.6L rear leaf sprung Monteros.
The V6 has coil springs, so for those models you swap in a late model (94-96 perferably) full size Montero SR axle.
So to answer your question the sport swap is not an aussie locker.
Re: Gen 1 LockRite Group Buy [Re: zarktheshark] #946803 06/02/09 12:12 AM
StockRaider Offline
Some Sport rear ends are equipped with factory Mitsubishi air lockers. I assume they are like the SR locker and have rear discs too. You can pick up an entire rear axle for around the price of an aftermarket locker. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Gen 1 LockRite Group Buy [Re: StockRaider] #946804 06/02/09 12:19 AM
rolling_down_the_hill Offline
instead of welding the rear or going into an axle swap if you dont want to, just get a gen 1 with a factory LS and swap it. it;s probably the cheapest easiest thing to do without welding your rear.
88 raider 4.3 about to be parted out.
87 raider 4cy on 32's
Re: Gen 1 LockRite Group Buy [Re: justice] #946805 06/02/09 12:44 AM
Oyaji_Jon Offline
To add on to what Justice said, the selectable locker is most desirable for the street/off street combination (in my opinion) because you can run fully locked or open whenever you feel the need.
That said, the reason the "lockrite" would be better than a welded diff is that it allows the diff to "ratchet" as the inner and outer wheels turn at different rates through tight turns on a "grippy" surface. There is some benefit in terms of tire wear when the rig is driven on the road a lot. There are also manufacturer recommendations regarding how much power you put to them and their reliability, but with the factory Montero/Raider 2.6, I don't consider that to be much of a concern. So, while this is not a selectable solution, it is a compromise for both uses.
I don't know enough about LSDs to give any type of knowledgable comparison, so I'll leave that to someone else.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Gen 1 LockRite Group Buy [Re: Oyaji_Jon] #946806 06/05/09 11:05 PM
87monty Offline
What if im going to run a Turbo 2.6 which will be soon I have it one a stand waiting for the day <img src="/forums/images/graemlins/smile.gif" alt="" /> Do you think it would be better if I just weld up the rear? I want a locker but the whole rearend swap "Thats if I could find one around here " seems to be alot of work. Has anyone here welded up the spiders?
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Gen 1 LockRite Group Buy [Re: 87monty] #946807 06/06/09 01:33 AM
Oyaji_Jon Offline
Personally, I think that the rear end swap is less involved than welding in the diff, but don't have first hand experience since I haven't gotten my hands on a rear end yet. If you can find one, I would go with the swap out of a Sport before welding the rear. Just my 2 pennies...
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Gen 1 LockRite Group Buy [Re: Oyaji_Jon] #946808 06/06/09 07:32 AM
swapping the rear end is easier than swapping the rear diff, and yes i have welded many diff's I even did a write up on here. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Gen 1 LockRite Group Buy [Re: TOASTY] #946809 06/06/09 12:13 PM
Mad_Scientist Offline
I guess it also depends on your particular skill set. Of course a diff must be welded sufficiently for it to be reliable. On the other hand by the time you find (IF you can) a leaf spring MS axle WITH a locker, bolts it up, replaced brake components (likely needed), got a pump, wired it all up etc...I would think the difference is trivial. I think there are a few people on here with SR axles bolted up but cannot lock it yet. OK, OK that's further than I've got and I've got 2 lockers <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Gen 1 LockRite Group Buy [Re: Mad_Scientist] #946810 06/06/09 03:58 PM
87monty Offline
If I was going to weld it up this is what I would do.
96 SR
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6490 MB (Peak: 0.7606 MB) Data Comp: Off Server Time: 2026-06-21 18:53:15 UTC
