Page 5 of 6 1 2 3 4 5 6
Re: Gen 1 LockRite Group Buy [Re: 0778drz110] #946821 06/07/09 10:27 PM
Kevin C Offline
You want to weld the spider gears together, and not the housing. <img src="/forums/images/graemlins/kewl.gif" alt="" />
The housing should already be welded together<img src="/forums/images/graemlins/pfft.gif" alt="" />...just don't weld to the carrier to the diff <img src="/forums/images/graemlins/kewl.gif" alt="" />
Too bad the front diffs do not have carriers. <img src="/forums/images/graemlins/nana.gif" alt="" />
Link for you
Whatever you say... <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Still has a carrier to me.
I can understand why your confused... The factory manual calls the casting that the ring gear and carrier are put into the differential case.
Thats on the front diff....
Straight out of the 87 Montero manual.
Kevin
Re: Gen 1 LockRite Group Buy [Re: 0778drz110] #946822 06/08/09 01:11 AM
K_Raider Offline
Go to an auto parts counter and ask for housing bearings. <img src="/forums/images/graemlins/lol.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: Gen 1 LockRite Group Buy [Re: K_Raider] #946823 06/08/09 06:23 AM
LandRaider Offline
Right.. Because parts store employees are the authority on automotive terminology. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
You would ask for differential case bearings, and they would likely produce them.
Re: Gen 1 LockRite Group Buy [Re: LandRaider] #946824 06/08/09 06:51 AM
K_Raider Offline
Re: Gen 1 LockRite Group Buy [Re: LandRaider] #946825 06/08/09 07:02 AM
StockRaider Offline
Being a former counter jocky at a parts store, I was able to interpret what they wanted if they asked for one and meant the other. I also was never a prick and said NO YOUR LOOKING FOR A CASE BEARING! <img src="/forums/images/graemlins/pfft.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Gen 1 LockRite Group Buy [Re: StockRaider] #946826 06/08/09 07:23 AM
K_Raider Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> Good man. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I'm guilty as to always call them a carrier bearing also. <img src="/forums/images/graemlins/smile.gif" alt="" /> I know the the actual carrier bearing is what connects 2 driveshafts together like on a Chevy. I don't know that much about the inside of the diff either..
EDIT- I typed in differential case bearings on Autozones website and it says We're sorry, but there are no results in this parts category for your 1989 Mitsubishi Truck Montero 4WD 2.6L 2BL 4cyl. Same for Advance Auto. Guess they call them something else.
Re: Gen 1 LockRite Group Buy [Re: K_Raider] #946827 06/08/09 02:33 PM
4ePikanini Offline
If you are gonna weld it (whatever way) please have it balanced as an unbalanced diff (due to the welds) will destroy your seals very quickly and give vibrations.
Karma's Law - For every action there is a multiplied reaction!
93 Pajero GLS 3.0 V6 LWB - SOLD
2001 Gen3 Di-D LWB - SOLD
2005 Touareg R5 2.5 TDi
Re: Gen 1 LockRite Group Buy [Re: 4ePikanini] #946828 06/10/09 12:45 AM
FatTony Offline
Everyone has different names for rearend parts. I have always called the part the ring gear bolts to a carrier, but I know that chrysler calls it a case in some of their books. Still, I have never had a problem getting carrier bearings for anything.
I haven't laughed this hard in a while, thanks <img src="/forums/images/graemlins/lol.gif" alt="" />
88 Raider sas, doubler, boggers
Re: Gen 1 LockRite Group Buy [Re: FatTony] #946829 06/10/09 08:34 AM
4ePikanini Offline
I don't see why this is funny. If you have ever felt what a couple of grams can do to your tires when they aren't balanced then just imagine what the weight of that welds will do to the turning parts in your diff.
Or have I got my stuff all mixed up?
Re: Gen 1 LockRite Group Buy [Re: 4ePikanini] #946830 06/10/09 03:08 PM
I always just used balanced welds....
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6486 MB (Peak: 0.7600 MB) Data Comp: Off Server Time: 2026-06-22 14:16:38 UTC
