Page 3 of 5 1 2 3 4 5
Re: New kind of lift [Re: minydigger] #947157 06/17/09 04:52 AM
fokion Offline
the length and angle of the joints of the half shafts is an other problem for consideration
too much offset rims may destroy your bearings rapidly...
Re: New kind of lift [Re: fokion] #947158 06/17/09 04:35 PM
k120189 Offline OP
i plan on keeping the stock track width and just add more travel. and an inch or so less offset on each side it all im gonna do..keep throwing possible problems at me this is helping me design this
<a href="www.pittsfieldcustomsclub.com/sportage.html" target="_blank">98 sportage</a>: warn manual hubs,upyourkia spacers, 104 tj springs, 235/75/r15 BFG T/A KO, tracker rims, cone air filter, custom cat-back with a skunk2 muffler. gonna be a 2.3L
Re: New kind of lift [Re: k120189] #947159 06/17/09 08:11 PM
fokion Offline
Thats exactlly what I hope you understand I am doing and not trying to be a smart <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: New kind of lift [Re: fokion] #947160 06/17/09 08:58 PM
fokion Offline
are you planing on lowering also the diff??
Re: New kind of lift [Re: fokion] #947161 06/17/09 09:36 PM
k120189 Offline OP
yes im gonna drop it 4 inches. im hoping dennis will post pictures of the drop brackets he had made.
so the front will consist of my modded upper arm/bushing system. 4 inch diff drop brackets. 4 inch lower control arm drop brackets. and until i go coil over a 4 inch strut spacer. along with the odds and ends like sway bar drop brackets yadda yadda. in the back im using tj 3 inch lift springs and extending the panhard bar and i might make a set of modified control arms so i can adjust it all. i want to get all the kinks outta this and make the kit or plans avalible to other kia nuts
Re: New kind of lift [Re: k120189] #947162 06/17/09 10:27 PM
jaboo5322 Offline
With that much travel in the rear, in my head i was seeing longer panhard rod mounts. I would just think that it would have too much angle, and shift the rear axle too much, if you had any weight in it, i guess. <img src="/forums/images/graemlins/smile.gif" alt="" />
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: New kind of lift [Re: jaboo5322] #947163 06/17/09 11:01 PM
k120189 Offline OP
good point..i was thinking the same thing..a mount would almost be easier too..
Re: New kind of lift [Re: k120189] #947164 06/18/09 02:25 AM
Dryver Offline
Perhaps instead of installing a longer panhard rod, you would need to go with a Watt's linkage setup to keep the rear axle from shifting.
01 Convertible; Electric Fan; 3" Up Your Kia lift spacers; Tj 104's; 31x10.5x15's on Centerlines; Rear LSD.
GONE, all I have left are a few spare parts and the wheels.
Re: New kind of lift [Re: Dryver] #947165 06/18/09 02:33 AM
jaboo5322 Offline
Watt did you say? <img src="/forums/images/graemlins/smile.gif" alt="" /> Hahahaha. <img src="/forums/images/graemlins/notooth.gif" alt="" /> Looks kinda cool. <img src="/forums/images/graemlins/smile.gif" alt="" />
1989 Dodge W250.
Re: New kind of lift [Re: jaboo5322] #947166 06/18/09 11:46 AM
minydigger Offline
I also dont think a bushing is going to work out in that app. as it will cause to much deflection and wear to quickly. You might use a hiem or a uniball of some sort.
94 Zj custom suspension and other stuff
01 F250 tow hoe 5" exhaust
00'sporty 3" lift 235's
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6390 MB (Peak: 0.7459 MB) Data Comp: Off Server Time: 2026-05-29 17:16:20 UTC
