Page 3 of 3 1 2 3
Re: Really rough idling and shakes [Re: StockRaider] #947372 06/01/09 08:40 PM
Mad_Scientist Offline
Gas is over a year old
<img src="/forums/images/graemlins/scared.gif" alt="" /> Get rid of that. I wouldn't run that through my lawn mower <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: Really rough idling and shakes [Re: StockRaider] #947373 06/01/09 11:40 PM
MarkG Offline
Gas is over a year old, and I have a massive fuel leak pre filter so its not very fresh gas either.
Oh mark, what is a DRBII? <img src="/forums/images/graemlins/confused.gif" alt="" />
You probably want to start here. This is the factory diagnostic manual. Read the section on drivability tests.
http://www.mitsubishilinks.com/fsm/raider_fsm_1989_powertraindiagnostics-30l.pdf
A DRB-II is the factory diagnostic tool. With it you can...
  • check the injector circuits
  • check the o2 sensor
  • check the engine temp sensor
  • check the air flow sensor sensor
  • check the engine rpm
  • check the air temp sensor
  • check throttle position sensor
  • check the crank angle circuit
  • check the air pressure sensor
  • check the fuel pump circuit
  • check the EGR temp circuit
Re: Really rough idling and shakes [Re: MarkG] #947374 06/02/09 04:31 AM
ghostraider Offline
Here is a Great link with lots of pix of the drb2 and MUCH more!
DRB-II INFO
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Really rough idling and shakes [Re: ghostraider] #947375 06/05/09 02:46 AM
StockRaider Offline OP
I was looking under the Montero where I saw the fuel leak which went from bad to horrible. I never knew a fuel line sheds its skin <img src="/forums/images/graemlins/scared.gif" alt="" />. What was left was a spongy mess of rust <img src="/forums/images/graemlins/barf.gif" alt="" />. I bought some injector hose and new 5/16thmetal line and replaced the 3 foot section of bad. I have to say it smoothed everything out quite a bit. Still ran like crap but I swapped Mass air sensors from a spare intake and it smoothed the whole thing out a great deal. I still have a check engine light and some shaking but its almost night and day compared to how bad it was. I still have to dump the old fuel before I can really see a difference I think.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Really rough idling and shakes [Re: StockRaider] #947376 06/06/09 04:43 AM
MarkG Offline
Sorry about the delay in getting the DRB-II on it's way. It is all boxed up and ready. I just need time to get it to the post office when they are open. I'm in a LP Fire Control class this weekend. I should have it on the way on Monday morning.
Re: Really rough idling and shakes [Re: MarkG] #947377 06/08/09 12:35 AM
Thanks for offering me the DRBII Mark. I am not sure if I need it anymore though. I was fiddling with the Montero and tore the intake down and reseated the fuel rail. After about 3 minutes of running the Check Engine light blinked off and the engine smoothed out. Still shakes a bit, but its almost like it should be running. <img src="/forums/images/graemlins/kewl.gif" alt="" /> I still have the shaking to deal with, and a mystery coolent leak has shown itself. Also a few corrosion gremlins are needed to be dealt with. But aside from that its running like it should... I was wondering if the ECU on the 89 Montero had a memory on it that would store an error code and keep it running poorly for a while after solving the problem?
Richard E
1983 Honda XL600R
Re: Really rough idling and shakes [Re: StockRaider] #947378 06/08/09 01:08 AM
engine smoothed out
Nice!! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Really rough idling and shakes [Re: Mad_Scientist] #947379 06/08/09 02:48 AM
themacway Offline
i have to replace fuel lines pretty often on both of our motorhomes' generators. cures the rough idling and shaking just about every time. i didn't even think about that for your problem. it might help me with my own little raider's rough idling a bit, as i've got a separate thread about that here somewhere. i'll go check it now. jack b :-)
'89 raider v-6, blue w/blue-grey, auto, superwinch hubs, a/c, cruise/tilt, bouncy, big wheels/tires/suspension and kewl ol' school trailmaster motorsport grill guard and body damage! now with a yammie xt600e duallie mounted across the rear.
Re: Really rough idling and shakes [Re: themacway] #947380 06/08/09 03:17 AM
I would try replacing the fuel filter before replacing the lines. This truck sat for over a year with road salt on it from the poconos. My 89Raider still has clean rust free lines because I wash the underside once a month. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1983 Honda XL600R
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6408 MB (Peak: 0.7463 MB) Data Comp: Off Server Time: 2026-06-20 19:19:50 UTC
