help me pass smog...
#947718
06/02/09 04:46 AM
so... state of kalif lists me a GROSS POLUTTER...
so i have to go every year for a smog test. and it's a smog test ONLY place.
on the dyno at 15mph, my HC number is 152. max is around 118. norm is around in the 30's...
recently did a completely tune up. plugs, wires, cap and rotor.
guess what? retest and the friggin thing went up 2 points?!?
what else is there?
it's been a while since i've swapped out the cat converter and the muffler.
help...
leo d. 90 4runner, v6, auto, WCOR CitB kit, marlin duals, arb rear, tt front 4.88, blah, blah, blah... Pres. of TEAM IFS! and GETTING OFF 4WD Club member
Re: help me pass smog...
[Re: ldivinag]
#947719
06/02/09 06:12 AM
Ralph
1991 Toyota 4x4 Standard Cab Pickup. engnbldr cam and head. Doug Thorley Headers Home Made Cat Backs 30x9.5x15 BF Goodrich All-Terrain M/T KM2
[Re: Ralph]
#947720
06/02/09 06:23 AM
Ralph
[Re: ldivinag]
#947721
06/02/09 06:38 PM
After you've replaced the cat and think you've exhausted your other options for fixing the root of the problem, then you might look into HHO systems as a catalyst for somewhat better emissions. A lot of people seem freaked out by them as if the whole concept is some sort of scam. It's not a scam. Do a little research. There are definitely related scams on eBay though. Rather than linking to any particular product or design, here are a couple links to reviews of various HHO designs so you can decide for yourself: http://www.hhoreviewstoday.com/http://www.squidoo.com/hhoreviewsor see what other people think about it at this forum: http://www.fuel-saver.org/Forum-Hydrogen-Brown-s-Gas-SystemsWhat I don't like about some of them (like the Gas4Free web site for example) is how they belittle the importance of how dangerous hydrogen can be. Particularly with 4 wheeling in mind, you might look into designs of a "bubbler" and/or a hydrogen flashback arrestor and/or maybe a safety device like: http://hhogassavermpg.com/default.htmlYou have to make sure that in a rollover, the water from a bubbler and the electrolyte chamber isn't going to drain into the air intake or otherwise create a hazardous situation. You also have to plan on an additional 20 amp load on your alternator. I have been researching this so I feel good about it and am in the process of building one for myself. So I don't have real world numbers yet.
Jeff 2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids 2007 Tacoma double cab 4x4 - stock
[Re: ldivinag]
#947722
06/03/09 03:21 AM
Has you mileage dropped off, could be a lazy O2 sensor. The cold start injector could be leaking fuel into the system as well.
If you are running an after market Cat, that is likely your problem.
After I rebuilt my the top end of my 3.0 in '04 it passed smog in '05 w/o issue. It was a little higher w/the magnaflow than past tests, but nothing to be concerned about. In '07 it failed only at idle(still not enhanced smog here) w/only 9k miles on the cat at idle for both the HC's and the C0% After testing/cleaning/checking everything and a few trips back w/no change, the tech reduced the idle and it just barely passed. This year it failed again, set at the same idle speed and w/only 3k more miles since the last smog check. Pretty sure it was the cat I came home pulled the Magnaflow off, installed the original oem one, went back the next day and passed w/o issue.
[Re: Snowtoy]
#947723
06/04/09 04:35 AM
after an expensive tune up, check engine came on... sigh... 12 and 71 codes... http://www.off-road.com/toyota/tech/codes/12 is RPM signal... wtf? and 71 is EGR... sigh... help...
[Re: ldivinag]
#947724
06/09/09 03:19 AM
Excessive fuel pressure? That was what was causing my HC woes...
[Re: ldivinag]
#947725
06/10/09 06:43 AM
Hey Leo, it's been a long time since I run into you...
I gotta go get my truck smog too... I hope I don't have the same problem you do. I had issue with TPS before which I passed smog by lowing the timing, passed smog then put it back to where it was...hehe.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are. It's freedom OF religion not from. 95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
[Re: carter]
#947726
06/10/09 07:16 AM
Excessive fuel pressure? That was what was causing my HC woes... Not sure if the V6 engines have the same vacuum modulated fuel pressure regulator that the 22REs have, but if so, make sure that vacuum line is connected as that drops fuel pressure when the engine load is low: - http://www.4crawler.com/4x4/CheapTricks/22RE_Engine_Pix/8.html
