upper ball joints on 95 4runner #947834 06/03/09 04:16 AM
carook Offline OP
Is this a hard job to do. Do you need any special tools. Thanks
Re: upper ball joints on 95 4runner [Re: carook] #947835 06/03/09 04:45 AM
Adam F Offline
Nope. Just pop the ball joint loose from the knuckle, remove the 4 bolts, and beat it free from the arm.
To pop the ball joint loose from the knuckle, get a 3 or 5 pound sledge hammer (gotta be a heavy one, not a regular framing hammer) and hit the very top of the knuckle where the ball joint goes through it. Should pop loose after a couple of GOOD hits.
Once you pop the ball joint loose from the knuckle, you need to push the upper arm up a little bit in order to free the joint. Might be able to do this by hand, if not put a bottle jack in between the upper and lower arm. Once its free, you can slide a block of wood in between the a-arm and the bump stop to keep it in place. Like so....
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5842 MB (Peak: 0.6321 MB) Data Comp: Off Server Time: 2026-06-06 14:10:44 UTC
