"Upgrades" for my 92 3.0l 12v ? #947998 06/04/09 12:07 AM
4runnerpilot Offline OP
I removed the engine from my 92 Montero the other day to do a full rebuild. It's got 185k miles, a rod knock and what I'd guess is a collapsed/failed HLA (or 2, or 5..)
Anyway, it's going to get a rebuild. Are there any tips or tricks to improving the engine? I saw in a post below that some of the engines (I think it was about a 3.5l 24v) can use the HLAs from a later Diamante or something.
I am planning a stock rebuild, but if there are later parts that are an improvement and don't take lots of specialty machining, I'd be in for trying them.
Thanks!
88 Trooper, 2.6 5spd
89 Trooper RS
92 Montero
Re: "Upgrades" for my 92 3.0l 12v ? [Re: 4runnerpilot] #947999 06/04/09 12:26 AM
FrankR Offline
When you replace the lifters (HLAs), use only the 3.0L 12v SOHC lifters on that engine. They all now have a 3mm or so hole instead of the original 1mm hole.
Frank
PHP: 7.4.33 Page Time: 2.148s Queries: 15 (0.004s) Memory: 0.5879 MB (Peak: 0.6364 MB) Data Comp: Off Server Time: 2026-06-13 14:30:32 UTC
