Spark plug wire keeps poping off of spark plug
#948844
06/10/09 07:12 PM
Has anybody had any trouble with the spark plug wire popping off of the spark plug on the 3.4L. Even when I push it down it will immediately pop back up. I used new wires. It only a problem when it pops completely out and then it becomes a 5 cylinder until i pop it back in. Any thoughts on how to fix it Thanks
Re: Spark plug wire keeps poping off of spark plug
[Re: 89toy96]
#948845
06/10/09 08:10 PM
Never had that problem.
What brand wires are you using? Sounds like they are too short.
I just installed NGK part number 4412 ($28 from rockauto.com) and they fit great.
[Re: Adam F]
#948846
06/10/09 11:52 PM
Probably a bad wire maybe..
[Re: Adam F]
#948847
06/11/09 05:55 AM
the wires are from the toyota dealership, i also thought that new wires would fix the problem. I am not sure about the spark plugs, haven't changed those in a while
[Re: 89toy96]
#948848
06/11/09 07:54 AM
It's possible that the spark plug top may be missing/broken. Since the wires are new and you checked the inside of the new wire fer possible problems, then the only thing left would be the plug. Like to see piccies when you find out what the deal is... <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: 89toy96]
#948849
06/11/09 02:14 PM
A possibility - some plugs have the screw on tip. Could be that is inside your wire fitting and causing a poor fit???
trafdlo
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6084 MB (Peak: 0.6775 MB) Data Comp: Off Server Time: 2026-05-30 05:17:33 UTCValid HTML 5 and Valid CSS
