5.13s with help with the power issues of the 2.6, but your MPG is going to go down the crapper. But you pay to play. 4.88s are probably more along the lines if you're going to run 33"s. 5.13s or 5.29s I would go with 34s or 35s.
DRaider90, dropping gears will help like you said but for a 2.6L with a manual transmission 4.88s are not deep enough. Assuming a 30" stock tire 5.13s are the minimum. If you pick the right ratio your MPGs do NOT have to go into the toilette. Under 'gearing' and over 'gearing' are probably the biggest cause of drivability issues I see - specifically poor millage.
I don?t really know the original tire set up... is came with 16" wheels.. the engine is a 2.6L 4 cylinders carburated, manual 4 speed transmission, all 1982 Gen I. I Assume that gear ratio is 4.623 ...
There are two ways to make your vehicle move. The American way - HP and torque - and the Japanese way - gearing. There is a big difference between tweaking a 2.0L ricer and tweaking a 350+CID muscle car. Now days you also get to toss a computer into the mix just for fun.
The basic idea when dealing with gear ratios and tire sizes on a stock to moderately modified, naturally aspirated (especially computer controlled) engine is to 'make the car think nothing has been changed'. Manufactures build 'slop' into all vehicles - there is always some leeway +/- from the stock configuration and you want to stay within that zone in order to keep everything happy. If you can select your combination of gears and tires to keep the end result within the mentioned 'zone' then the vehicle will perform substantially the same as it did before the changes.
x+y+z=47
In other words, if your stock configuration = 47, you can change x, y, and/or z but the answer at the end of the day still needs to equal 47. If you can manage that your gas millage and driveability will remain close to stock.
The first thing I recommend is figure out what the stock tire size was in diameter - you really need this information. Figure out what your new tire diameter will be. You can get real picky here and actually measure the diameter - just 'cause it SAYS 35" doesn't mean it is. 4.62 sounds about right but I'd make sure - this is not the place to make a mistake. Once you have all the information click on the link below and punch your data into "Find new Gear Ratio with new tire size".
Calculate Gear Ratio, Tire Size, etc. Just for grins: 31" original tire, 35" new tire, 4.62:1 original axle ratio = 5.21:1
The calculator will feed you back the mathematical gear ratio you need to exactly match the factory installed tire size and ratio. A lot of the time the ratio will be between available gear sets so some compromise is necessary (see example). Doing what we do (bigger, heavier, wider tires) it's usually best to go to the next deepest (numerically higher) set of available gears.
Again, for grins: next lowest is 5.29:1
So, now you should have a ratio to work with. Now is the time to make additional tweaks to that ratio to compensate for altitude (beyond what the manufacture expected the vehicle to be driven at), weight, aerodynamic efficiency (roof racks, bull bars), driving pattern (lots of stop and go or lots of highway. for lots of stop and go you can go deeper and for lots of highway you can go taller - numerically smaller number), engine size/age and engine (including exhaust/intake) modifications (those that affect torque output). This will end up being your ACTUAL, 'real life' ratio.
So, our example ratio of 5.29:1 turns into: more weight @ 6,000FT average altitude = 5.38:1 A 5.5ish:1 would probably be a better choice if there's lots of stop-n-go (and the engine has 450K miles on it:) as a DD.
A good - general - rule of thumb is one step deeper (numerically higher) on a reasonably stock vehicle. 'Reasonably stock' = a small roof rack, bull bar w/winch, with some millage, running at around 4-5000FT and w/ moderately wider tires.
There is a limit on how deep you can go with gears. Obviously, if they're not available then that's the end of that. With deeper (higher numerically) gear sets there is less contact area from the pinion to the ring. Running 6:1 gears on 44"s with a 500HP engine is probably not such a good idea. So, even if the manufacture selection were infinite the number of practical selections is not. Running 5:1+ gears also transfers all the torque to the axle shafts and everything connected to them outboard of the differentials. Gear reduction is a wonderful thing but it's very easy to unintentionally exceed the operational specs of parts. <img src="/forums/images/graemlins/frown.gif" alt="" /> High quality axle shafts and u-joints are always a very good idea.
There are variables that go into the calculation for serious gear ratio/tire selection that I didn't get into that still should be considered but the above is a good place to start.
