radiator has a small leak #950229 06/20/09 05:51 AM
G
graeaglecrawler Offline OP
It's has a small weeping leak on the top on the inlet side and it fills the small lip on the engine side of the radiator, has anyone had these resoldered or where is a good online place to buy one?
'91 montero a/t cranked t-bars 31x10.5x15 212k
'90 toyota extra cab 320k v6 5 speed 31's 4x4
'99 expedition 17" alloys v-8 207k 4x4
'88 BMW 325iX 247k AWD
'59 Willys Jeep Koenig PTO winch and hardtop 28k
Re: radiator has a small leak [Re: graeaglecrawler] #950230 06/20/09 06:10 AM
Yes, you can resolder a small leak, but look at the overall picture - where there's one leak now, more may be behind door #3. I'd have your radiator serviced, rod out & boiling, fix whatever needs, reinstall and go.
Russell
Re: radiator has a small leak [Re: graeaglecrawler] #950231 06/20/09 04:01 PM
Trooper-san Offline
I had this happen on my old Trooper--a small hole/leak in the upper radiator tank, facing the front of the vehicle.
Russell has just given you the proper answer, the 'by the book' procedure. I went the cheap route and used JBWeld to plug the hole. That was four or five years ago. There hasn't been a problem since. But, as Russell said, a leak is probably an indication of the overall condition of the radiator. The rest of it may not be far behind that leak, so be prepared to follow the more correct path.
1989 Trooper, 2.6
1989 Trooper, 2.8
1992 Ford F-350, 7.3
My Photos
PHP: 7.4.33 Page Time: 0.021s Queries: 15 (0.015s) Memory: 0.5914 MB (Peak: 0.6447 MB) Data Comp: Off Server Time: 2026-10-25 14:25:43 UTC
