Page 2 of 3 1 2 3
Re: 88 truck on 85 axles and broke! [Re: TayJ] #950253 06/22/09 03:55 AM
kewlynx Offline
Here's a link with a few pics to give you an idea of what's lacking under the rear end TayJ.
Modded '82
**ubi apis- ibi salus**
Re: 88 truck on 85 axles and broke! [Re: kewlynx] #950254 06/23/09 04:05 AM
BROWNBAGG Offline
the blocks broke it
Re: 88 truck on 85 axles and broke! [Re: BROWNBAGG] #950255 06/23/09 05:12 AM
TayJ Offline OP
Thanks all, this is the first leave sprung crawler I have delt with. Blocks will be gone, going with better leaves, probably the trail gear ones and going to make an anti-wrap bar.
What else do I need to do to make this thing ready to rock and in a way that we won't need to worry about it?
Jeep
Jus' sayin'
88 on 1 tons! [Re: TayJ] #950256 06/28/09 09:26 PM
TayJ Offline OP
So the decision has been made. Going to keep running the 40 inch Iroks but going to scrap the toy axles and swap in a Dana 60 front and 14 bolt full float rear! More than likely it will still be sitting on leafs front and rear but the idea of a rear four link is being tossed around.
Jeep
Jus' sayin'
Re: 88 on 1 tons! [Re: TayJ] #950257 06/28/09 09:30 PM
TayJ Offline OP
So we got it sitting on the rear axle again with the block under the spring so it will be sitting more level so we can get started.
While we are waiting on the axles and new wheels we are going to cut off the rock sliders, remove the body lift and put the sliders back on.
Jeep
Jus' sayin'
Re: 88 on 1 tons! [Re: TayJ] #950258 06/29/09 02:33 PM
Billydkid Offline
Your front spring perches look kinda scary in those pics. I have heard of sas spring perches that weren't reinforced enough breaking loose.
93 4runner V6, 4.88's, 31" mt's with more to come.
03 Tundra V8 on 265's
Re: 88 on 1 tons! [Re: Billydkid] #950259 06/30/09 06:18 AM
TayJ Offline OP
Swapping in D60 front so we will have a chance to make real strong perches! Thanks
Jeep
Jus' sayin'
Re: 88 on 1 tons! [Re: TayJ] #950260 06/30/09 06:43 AM
kewlynx Offline
Anything stronger than what's under there will be a good thing. <img src="/forums/images/graemlins/rodent.gif" alt="" />
BTW, what's that little pickup I see a corner of to the right? <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: 88 on 1 tons! [Re: kewlynx] #950261 06/30/09 02:01 PM
bkg Offline
Blocks had nothing to do witht he problem - they're mounted on top of the springs as a spacer.
Those leafs simply have no ability to prevent axle wrap... three thin leafs w/ no overload - they never had a chance.
An trac bar is the best bet if you need to keep the thin pack. Budbuilt has a bolt on unit.
Brian K. Gallus
Re: 88 on 1 tons! [Re: bkg] #950262 06/30/09 02:28 PM
K_Raider Offline
I'm guessing since the rear is much lower than the front in the first set of picks, they just threw it back together with the blocks above the springs instead of the blocks under spring.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6404 MB (Peak: 0.7482 MB) Data Comp: Off Server Time: 2026-06-07 11:16:05 UTC
