Re: 88 on 1 tons!
[Re: K_Raider]
#950263
07/01/09 01:01 AM
Blocks had nothing to do witht he problem - they're mounted on top of the springs as a spacer. I'm guessing since the rear is much lower than the front in the first set of picks, they just threw it back together with the blocks above the springs instead of the blocks under spring. Ah... I see your point!
Brian K. Gallus I have nothing important to say.
Re: 88 on 1 tons!
[Re: bkg]
#950264
07/01/09 02:30 AM
Your right about the springs though. Theres just not enough there especially with the torque those dual cases are trying to put on the ground. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors 89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels 99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
Re: 88 on 1 tons!
[Re: K_Raider]
#950265
07/03/09 04:58 AM
Is that teh stock radiator? It looks really tall - hard to tell, but almost like if yo uwere to take those massive body lift pucks out, it'd be sticking through the hood.
Question Reality. ----------------------------- '89 Rnr DLX "SR4.5", 32s w/ 5.29 locked f/r blah blah
Re: 88 on 1 tons!
[Re: kewlynx]
#950266
07/03/09 06:35 AM
Anything stronger than what's under there will be a good thing. <img src="/forums/images/graemlins/rodent.gif" alt="" />
BTW, what's that little pickup I see a corner of to the right? <img src="/forums/images/graemlins/cyclops.gif" alt="" /> 49 chevy there! I will post a pic of it here, beautiful truck. I am hoping to be building a 46 chevy here soon.
Jeep Jus' sayin'
Re: 88 on 1 tons!
[Re: K_Raider]
#950267
07/03/09 06:37 AM
Blocks had nothing to do witht he problem - they're mounted on top of the springs as a spacer. I'm guessing since the rear is much lower than the front in the first set of picks, they just threw it back together with the blocks above the springs instead of the blocks under spring. Exactly! Trail repair, thats why the blocks ended up on the spring.
Re: 88 on 1 tons!
[Re: RatLabGuy]
#950268
07/03/09 06:39 AM
Is that teh stock radiator? It looks really tall - hard to tell, but almost like if yo uwere to take those massive body lift pucks out, it'd be sticking through the hood. Stock radiator, and if the body lift is taken out it will lower the radiator with the body since the rad is mounted to the body.
Jeep Jus' sayin'
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6173 MB (Peak: 0.6877 MB) Data Comp: Off Server Time: 2026-07-14 09:35:27 UTCValid HTML 5 and Valid CSS
