valve stem seals 87 4cy. #950904 06/25/09 02:29 PM
rolling_down_the_hill Offline OP
started tearing it apart and have a ? or 2.can i just remove the valve cover? i dont want to screw my timing all up in the process. is there a trick to it or is it as simple as it seams to be. and i did search the arcives but didnt find anything as far as details explaining what they did.
88 raider 4.3 about to be parted out.
87 raider 4cy on 32's
Re: valve stem seals 87 4cy. [Re: rolling_down_the_hill] #950905 06/25/09 07:24 PM
Oyaji_Jon Offline
You remove the rocker cover and the rocker arm assembly. Use a valve spring compressor to pull the springs and you can get at the seals. I recommend going to Napa and getting the spark plug adapter to run compressed air into the cylinder to keep the valve in place while you change the seals. I just did the procedure last week on my V6 and used to have a 2.6L. The procedure is similar with the difference being how much $hit you have to remove to get to the valve cover. HTH
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: valve stem seals 87 4cy. [Re: Oyaji_Jon] #950906 06/26/09 02:59 AM
ty, i got the tools required already. and jay gave me a book tonight telling me the same thing to.
Re: valve stem seals 87 4cy. [Re: rolling_down_the_hill] #950907 06/26/09 06:53 PM
P
pcc Offline
Just a tip, or two. The cylinder will leak compressed air as you change seals. With the summer and the humidity the compressor air will have a lot of water in it. If you have a water trap keep an eye on it as it will fill up quickly. I'd advise a complete oil change before starting the engine to remove any water in the pan oil. Use a small screw driver tip magnet to remove and re-install keepers.
Re: valve stem seals 87 4cy. [Re: pcc] #950908 06/26/09 07:20 PM
i am, got new oil n filter waiting, and after about 300 miles im changing again for insurance. and ty for the tips.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6029 MB (Peak: 0.6676 MB) Data Comp: Off Server Time: 2026-06-10 03:25:18 UTC
