Page 3 of 6 1 2 3 4 5 6
Re: My New Tracker (project)! [Re: TayJ] #953266 07/21/09 01:39 AM
lordtrunks Offline
There is a guy here in aj with a sas'd tracker i'll stop and talk to him for you next time i see him. His is leafed up looks like waggy stuff from what i remember.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: My New Tracker (project)! [Re: lordtrunks] #953267 07/21/09 02:14 AM
TayJ Offline OP
Yeah man, if you could do that for me. Maybe ask him if it would be okay for me to stop by and check it out?
Thanks
Jeep
Jus' sayin'
Re: My New Tracker (project)! [Re: TayJ] #953268 07/23/09 05:25 AM
TayJ Offline OP
Removed the axles/cut [censored] off today. Looking at a set of waggy D44s right now. I hope the deal goes through and I can start putting something good into the track-attack!
Jeep
Jus' sayin'
Re: My New Tracker (project)! [Re: TayJ] #953269 07/25/09 08:56 PM
TayJ Offline OP
Worked some on the tracker project, should have axles either Sunday, july 25 or a few days after.
Removed the rear axle.
Removed the front axle, still have more stuff to remove.
It got too hot outside, might go cut more out later.
Need beer first though! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Jeep
Jus' sayin'
Re: My New Tracker (project)! [Re: TayJ] #953270 07/25/09 09:15 PM
1
1986powerram50 Offline
Tay it does look hot out there.
What you doing for axles? D44s?
What kind of gears you gonna run in that thing if your keeping stock motor?
Is there any aftermarket support for the T case?
--keRby
Ad Inexplorta
Re: My New Tracker (project)! [Re: 1986powerram50] #953271 07/25/09 09:28 PM
TayJ Offline OP
I am trying to find some aftermarket t-case support or find some kind of swap for a t-case with aftermarket support.
As for axles it is looking more like toyota axles, 81 with 5.71 gears....that might change but if all goes to plan....we will know tomorrow.
Motor is staying and so is tranny and t-case for now...till I find what is better.
Jeep
Jus' sayin'
Re: My New Tracker (project)! [Re: TayJ] #953272 07/25/09 11:04 PM
1
Wheelbase isnt longenoughto run a divorced set up is it?
Shucks I got an 85 yoter front axle up here w/ all the gussets and the whole 9.
Motor options are gonna be tough I bet a 4.3 wont even set in there. Maybe like a ford 2.3 or something they have a decent aftermarket.
--keRby
Ad Inexplorta
Re: My New Tracker (project)! [Re: 1986powerram50] #953273 07/25/09 11:14 PM
TayJ Offline OP
Dang, I need your axle!
Yeah, divorced won't work.
I found this though:
http://www.trailtough.com/index.php?opti...8&Itemid=53
Trail tough has a good amount of stuff for a tracker. I found the t-case low stock is 1.8:1. I want the trail tough 4.24:1 t-case gears. $650 is steep though!!!!
Jeep
Jus' sayin'
Re: My New Tracker (project)! [Re: TayJ] #953274 07/26/09 12:12 AM
TayJ Offline OP
Oh man! Bad news in the final crawl ratio area!
Tranny gears are:
1st 2.40
2nd 1.47
3rd 1.00
Reverse 2.00
T-case gears
High 1.00
Low 1.82
This means I will need the underdrive of 1.5:1 and the new t-case gears of 4.24:1 low.
All that with a axle gear ratio of 5.71:1 puts me at around 85:1 final crawl ratio.
Now thats not a bad number for an auto tranny....but!
The undertaker underdrive cost $1295.00
The 4.24:1 t-case gears cost $650
The axles I am looking at with 5.71 gears cost $500
Im really getting deep here....I just wanted to throw axles at it and go wheel.
Now Im looking at slip yoke eliminators and new drive shafts and.....a bunch of crap!
DRUNK RESEARCH AND POSTING!!!
<img src="/forums/images/graemlins/cheers.gif" alt="" /><img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Jeep
Jus' sayin'
Re: My New Tracker (project)! [Re: TayJ] #953275 07/26/09 01:48 AM
1
One of them yoter axles I have is COMPLETLY redone to all seals, shims, brakes got upgraded and painted. BTW if ya do redo an axle w/ birfs dont remove the shims off the bearing on top and bottom of em. Keep track of em its a b!tch to have to reshim em one at a time. Trying to make certain theres 0 play in em
650 aint bad for Tcase gears. All the mitsu tcase gears are atleast 1000
Maybe just get the t case gears and w/ your axles at 5.71 you should be good enough I'd like to think.
How big of a tire you gonna run?
--keRby
Ad Inexplorta
Moderated by  4x4Wire, code33
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6424 MB (Peak: 0.7512 MB) Data Comp: Off Server Time: 2026-05-27 21:17:21 UTC
