3 " body lift on auto tranny sportage
#953491
07/13/09 12:41 AM
Hi, Just wondering if anybody has installed the 3" lift on a sportage with an automatic tranny? I'm wondering what sorts of problems I might run into. Thanx.
2000 with Eibach Suspension lift,Warn man. hubs,K&N air filter,15x8 mags with 31's, 3.75" body lift.
Re: 3 " body lift on auto tranny sportage
[Re: 5jackz]
#953492
07/14/09 03:22 AM
the fornt brake lines need to be bent alittle and the shift linkage and the transfer shifter u will need to cut the floor or bend stick and ac watch closely pw steering res relocated aaaaa auto shifter just lenghten the bar a little ooooo make sure u disconnect from under car bfore starting because it jams pretty tight into park after lift truuuust me in a hurry if u need more help pm me ill have more time tuesday mine was 3.75 body lift
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
[Re: jays2001]
#953493
07/14/09 05:52 AM
[Re: 5jackz]
#953494
07/15/09 01:08 AM
also the steering will come into contact with the small brake line box below the master cylinder on the fender i just bent the fender out problem solved. i can take pics just let me know
[Re: jays2001]
#953495
07/16/09 05:38 AM
Does anything have to be done with the hand brake?
[Re: 5jackz]
#953496
07/17/09 02:29 AM
[Re: jays2001]
#953497
07/23/09 06:07 AM
you can also use an extra rear brake hose to lengthen the front brake hoses on some years, i know it works on 95's... that way, no bending, and plenty of room for droop...
95 Sportage w/welded and 5.89 geared dana 44's on 38.5" TSL's.- SADLY SOLD CURRENTLY - 2000 sportage, 5.38 gears, welded diffs, 35" tires, 5.5" lift http://www.cardomain.com/ride/341410
[Re: Dave Scott]
#953498
07/23/09 06:26 AM
[Re: 5jackz]
#953499
07/25/09 11:52 PM
This has been a real serious interest to me regarding Sporty and body lifts..........
Is anyone going to post Pictures anytime soon??????
Just wondering....
[Re: Hydra747]
#953500
07/26/09 01:09 AM
what pics you looking for of what needs done or ????
