Page 1 of 3 1 2 3
Driveway sealer #953645 07/13/09 08:32 PM
Bigbird79 Offline OP
IÆll start by saying I am just starting to collect data and opinions on this subject, so letÆs hear what people think? I donÆt know how old my driveway is or if it's ever been sealed or coated, but the house was built in 1955 so I can only assume so was the driveway, and the driveway is in decent enough shape, no major holes or anything, but there are a few cracks running through it that the ants seem to be crawling through, and slowly moving the dirt that is under my driveway to on top of the driveway. I was thinking before it gets too bad and my truck sinks too much deeper, I should look at repairing the damaged areas, give it a good cleaning and put on a coat of sealer, but I figured I would see what others thought. Part of me wonders if the sealer would do more damage than good, but if the driveway is properly cleaned and prepped it feel like it would be a benefit, and it should help with the curb appeal a little. I stopped by the local Home Depot at lunch today, and it all looks reasonable.
So what are your thoughts?
Do you have a preference in brand or materials?
Is there any reason for the individual to not take on this project and hire someone to do it?
Are there any ôgot yaö type things I should watch out for before hand?
Thanks,
Sean
Re: Driveway sealer [Re: Bigbird79] #953646 07/13/09 09:12 PM
stony-man Offline
Concrete or asphalt?
Re: Driveway sealer [Re: stony-man] #953647 07/13/09 09:40 PM
Yup, concrete or asphalt?
I can give you a learned opinion on either. I build and rebuild asphalt tennis courts, and have paved roads and parking with plant mix. I also pour a LOT of concrete, both new and rehab.
PM me or I'll do it out here for the edjikation of the masses....
Re: Driveway sealer [Re: fasteddy] #953648 07/13/09 10:08 PM
my apologies. It's asphalt.
Thanks
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
Re: Driveway sealer [Re: fasteddy] #953649 07/13/09 10:12 PM
ScottFW Offline
None of that PM stuff. Post it out here because I need edgeyoucatin' too. My driveway sounds similar to bigbird's, just small cracks that I don't want to become bigger cracks. My driveway is concrete BTW. <img src="/forums/images/graemlins/smile.gif" alt="" />
'85 4Runner (mostly stock) <img src="/forums/images/graemlins/kewl.gif" alt="" /> | '94 Miata <img src="/forums/images/graemlins/smile.gif" alt="" /> | '98 Saturn SC2 <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> | '12 Ford Fusion (wife's company car)
Re: Driveway sealer [Re: ScottFW] #953650 07/13/09 11:13 PM
Asphalt:
You can't fix cracks. They always reopen. You can patch any pothole if you repair what's soft under them that caused the hole (subbase failure). Normal paving useful life is about 15years. Sealcoating and crack repair may give you 5 years more of useful life. You may get away with a new 1" dressing topcoat for not much more than sealcoating, and put off the seal coating for 3-5yrs. Generally, if the paving is still at the levelness (no vertical displacement on the cracks, and there are few/no potholes, I'd put a new top coat on, preceded by chasing out the cracks to remove all loose stuff and leave a big enough gap to fill with crack repair compound, plus a tack coat all over. Surface must be VERY clean. Be aware that putting down a new dressing coat will leave a small hump going down into the garage, if any. Cutting out 3-4' of asphalt there gives you room for a reasonable taper into the garage. I hope it's not downhill down the drive into the garage...
Asphalt has several enemies. road ice, water penetration to the sub base, sun, and traffic. asphalt is petroleum based asphalt cement (a very heavy tar that melts around 130*f), sand, and crushed stone aggregate of varying size depending on mix specs and final use. It has very little tensile strength, much less than concrete, and is really just a modified sealer of the surface to keep moisture off the earth sub base, which will soften when wet, deform under load, and let the asphalt and rock base above come apart in a pothole. Cracks are due to age (progressive hardening/brittleing of the surface due to loss of volatiles over time and polymerization due to sun and ozone and road crud, and/or sub base movement such as settling fill, or root intrusion. I like to trench along every asphalt surface to a depth of around 2', and line the side of the trench with visqueen sheet plastic to block root intrusion. Some salt in the trech is good, too.
Concrete:
You can't fix cracked concrete, only demo it and repour. If you have no vertical displacement, it's possible to do a 2-3" cap pour in concrete if you use something to break the bond between new cap and old pour, like geotechical fabric, a coat of sand, or visqueen plastic, which may or may not let new cracks open up over old ones, or cap the concrete with an inch of asphalt and tack coat, but the cracks in the concrete will show up in the new asphalt. It is possible to cut concrete cracks out wider (at least 6") and pour patches, especially if you dowel/epoxy rebar into the old surrounding slab edge and tie to new rebar in the crack, thus tying new to old vertically. I like to add a touch of hydraulic cement to the fill mix, as it swells slightly on cure and will lock new to old that way.
The most important part of pouring concrete to avoid cracking is not to avoid it, but control it, like perforations in toilet paper. You diamond saw cut 1-2" deep control joint kerfs in the new pour within 3 days of the pour, in a pattern which leaves no more than 100sf of concrete inside a polygon of cuts. In a driveway, unless it's wider than 10', you need a joint across the drive every 10'. The crack will (mostly) occur at the cut. Concrete cracks for two main 1usually reaches 90% of rated compressive strength (usually 3000psi) by 28 days after pour if kept sealed, and will increase in strength for around a 100years, after which time it will begin to lose strength and revert to sandy/gravelly components. Concrete will benefit from a sealer every 2-3 years after the final cure (follow directions, but a couple of months is good for the first coat) to avoid water penetration of the concrete and resulting spalling of the surface on freeze/thaw.
Both MUST have a properly compacted earth sub base, to what's called 95% Standard Proctor compaction (damn hard) such that the surface does not sink, then rebound under the load of a tandem dump truck tire (pumping). Tighter is better.
A minimum concrete slab is 4" nominal, usually around 3.5" since it's formed with usually 1x4 nominal lumber (3/4" x 3 1/2" actual). A minimum asphalt driveway is 4" of compacted crusher run stone base (rocks from 3/4" down to rock dust in standard proportions) capped by 2" of top coat. Better is 6" of CSB rock, with 1.5" of type B asphalt binder course, topped with 1" of type f or g topping.
Get a certificate of insurance from the contractor's insurance broker for work. comp and gen. liability and non-owned auto BEFORE they start work. Written contract, and READ IT. Get lien waivers in proper form for your state from asphalt plant, truckers if hired out, and the contractor BEFORE you pay a dime. No money up front. No payment for unaccepted work, but get the lien waiver BEFORE you tell him...
Re: Driveway sealer [Re: fasteddy] #953651 07/13/09 11:21 PM
So in short, the sealer isn't going to stop the ants.
Thanks for the info.
Sean
Re: Driveway sealer [Re: Bigbird79] #953652 07/13/09 11:24 PM
Poison the little buggers. Boric acid or sevin dust. They won't eat the crack sealer, but they can get thru ridiculously tiny cracks, but won't if it's poisionous down there...
They come up thru concrete cracks, too. Same solution...
Re: Driveway sealer [Re: fasteddy] #953653 07/13/09 11:29 PM
yup poison has been the temporary fix, I was just hoping sealer would seal up all the little holes they sneak through.
Re: Driveway sealer [Re: Bigbird79] #953654 07/14/09 01:19 AM
They be so sneaky they can get thru a hole that's not even there...
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6471 MB (Peak: 0.7790 MB) Data Comp: Off Server Time: 2026-06-05 03:34:29 UTC
