Gen 3 Change Fluid in Rear Differential
#953943
07/15/09 08:34 PM
How do I get fluid into the rear Differential in my 03 montero? I drained the fluid I tried to pump into one of the two fills and it shoots right out i can't get none in. What I'm I doing wrong?
2003 Montero Limited White 2001 Montero GLS Diesel 1990 Montero Black Off Road Package. 1990 Montero Parts Truck.
Re: Gen 3 Change Fluid in Rear Differential
[Re: koolaid6666]
#953944
07/16/09 07:12 PM
[Re: koolaid6666]
#953945
07/16/09 08:33 PM
Your not doing anything wrong...the tube is not in all the way. Make sure to wiggle the tube that you are using to put the fluid in around a lot and it will go in further. If it doesnt, use somethings smaller and then fill it till fluid comes out the top hole.
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
[Re: icysyrup]
#953946
07/16/09 11:37 PM
lol I have to try that. You have to see my driveway gear oil all over. I just changed a engine in another car and here I am can't change diff fluid.
[Re: koolaid6666]
#953947
07/17/09 12:08 PM
Hey no worries.....its always the little stupid stuff that seems to give the most trouble
[Re: icysyrup]
#953948
07/17/09 02:24 PM
You mean it's not supposed to take a week to change the oil in a diff??? <img src="/forums/images/graemlins/smile.gif" alt="" />
[Re: hazy_daze]
#953949
07/18/09 01:11 AM
going to do it this weekend I never saw two fill holes before on A rear Diff. ![[Linked Image]](http://img.villagephotos.com/p/2004-8/805561/Montero%20rear.JPG)
[Re: koolaid6666]
#953950
07/18/09 01:12 AM
The fluid Around the bolts were from Me Spilling Fluid wouldn't pump In.
[Re: koolaid6666]
#953951
07/18/09 01:15 AM
One Bolt isn't tightened. ![[Linked Image]](http://img.villagephotos.com/p/2004-8/805561/DSC00504.JPG)
[Re: koolaid6666]
#953952
07/18/09 05:25 AM
ummmmm <img src="/forums/images/graemlins/shame.gif" alt="" />....thats not where you put the oil in......go the the drivers side in front of that.....one drain plug bottom and then fill plug drivers side half way up. Those are the mounting point for the third member.
