Gen 3 Change Fluid in Rear Differential #953943 07/15/09 08:34 PM
koolaid6666 Offline OP
How do I get fluid into the rear Differential in my 03 montero? I drained the fluid I tried to pump into one of the two fills and it shoots right out i can't get none in. What I'm I doing wrong?
2003 Montero Limited White
2001 Montero GLS Diesel
1990 Montero Black Off Road Package.
1990 Montero Parts Truck.
Re: Gen 3 Change Fluid in Rear Differential [Re: koolaid6666] #953944 07/16/09 07:12 PM
Anything?
Re: Gen 3 Change Fluid in Rear Differential [Re: koolaid6666] #953945 07/16/09 08:33 PM
icysyrup Offline
Your not doing anything wrong...the tube is not in all the way. Make sure to wiggle the tube that you are using to put the fluid in around a lot and it will go in further. If it doesnt, use somethings smaller and then fill it till fluid comes out the top hole.
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: Gen 3 Change Fluid in Rear Differential [Re: icysyrup] #953946 07/16/09 11:37 PM
lol
I have to try that. You have to see my driveway gear oil all over. I just changed a engine in another car and here I am can't change diff fluid.
Re: Gen 3 Change Fluid in Rear Differential [Re: koolaid6666] #953947 07/17/09 12:08 PM
icysyrup Offline
Hey no worries.....its always the little stupid stuff that seems to give the most trouble
Re: Gen 3 Change Fluid in Rear Differential [Re: icysyrup] #953948 07/17/09 02:24 PM
Happy Birthday hazy_daze Offline
You mean it's not supposed to take a week to change the oil in a diff??? <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Gen 3 Change Fluid in Rear Differential [Re: hazy_daze] #953949 07/18/09 01:11 AM
going to do it this weekend I never saw two fill holes before on A rear Diff.
Re: Gen 3 Change Fluid in Rear Differential [Re: koolaid6666] #953950 07/18/09 01:12 AM
The fluid Around the bolts were from Me Spilling Fluid wouldn't pump In.
Re: Gen 3 Change Fluid in Rear Differential [Re: koolaid6666] #953951 07/18/09 01:15 AM
One Bolt isn't tightened.
Re: Gen 3 Change Fluid in Rear Differential [Re: koolaid6666] #953952 07/18/09 05:25 AM
icysyrup Offline
ummmmm <img src="/forums/images/graemlins/shame.gif" alt="" />....thats not where you put the oil in......go the the drivers side in front of that.....one drain plug bottom and then fill plug drivers side half way up. Those are the mounting point for the third member.
PHP: 7.4.33 Page Time: 5.373s Queries: 16 (0.003s) Memory: 0.6362 MB (Peak: 0.7591 MB) Data Comp: Off Server Time: 2026-06-23 15:24:42 UTC
