Torsion Bars
#954140
07/17/09 07:25 AM
I am looking to pick up a set of sway-away Torsion Bars bars but they don't list any thing later than 94
This is the size they list Mitsubishi Montero 4X4 1990-1994 27.5mm 53 13/16ö 1737 They also have this Mitsubishi Pickup 4WD 1990-1997 26mm 53 13/16ö 1736
I just need to know what size are on a gen2.5
92 Galant vr4 11.17at132mph 98 Montero 2.5"lift,33/10.50/15,15x8procomp wheels. trail-gear rock sliders,ARB front bumper,Warn m8000 winch. Piaa lights.
Re: Torsion Bars
[Re: Brianawd]
#954141
07/17/09 12:18 PM
I thought Gen1 and Gen2 torsion bars were different lengths. Didn't GrassCat try to install Gen2 bars and they wouldn't fit. May be wrong <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Torsion Bars
[Re: Brianawd]
#954142
07/17/09 03:28 PM
I know there were some made for our trucks, but they have been discontinued for many years now. Someone will know, but i cant recall the length myself. Any numbers to sway a way? Ever checked into Iron man torsion bars?
Re: Torsion Bars
[Re: Mad_Scientist]
#954143
07/17/09 04:09 PM
I thought Gen1 and Gen2 torsion bars were different lengths. Didn't GrassCat try to install Gen2 bars and they wouldn't fit. May be wrong <img src="/forums/images/graemlins/cheers.gif" alt="" /> that is correct. he found that they were different lengths. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Torsion Bars
[Re: ghostraider]
#954144
07/17/09 04:12 PM
I thought Gen1 and Gen2 torsion bars were different lengths. Didn't GrassCat try to install Gen2 bars and they wouldn't fit. May be wrong <img src="/forums/images/graemlins/cheers.gif" alt="" /> that is correct. he found that they were different lengths. <img src="/forums/images/graemlins/kewl.gif" alt="" /> In that case listing the same t-bars for 1990-1994 is BS <img src="/forums/images/graemlins/shame.gif" alt="" />
Re: Torsion Bars
[Re: ghostraider]
#954145
07/17/09 04:18 PM
wouldn't one of these work? (from sway away site) Dodge PU/Raider 4WD 1982-1989 26mm 50 1/2" 1726 $330.00 Dodge V6 4WD 1990-1997 26mm 53 13/16" 1736 $300.00 Dodge 4x4/Raider 1990-1994 27.5mm 53 13/16" 1737 $220.00
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab '15 Subaru XV '03 BMW i325
Re: Torsion Bars
[Re: zarktheshark]
#954146
07/17/09 04:19 PM
i'm retarded. later means newer:|
Re: Torsion Bars
[Re: zarktheshark]
#954147
07/17/09 04:21 PM
wouldn't one of these work? (from sway away site) Dodge PU/Raider 4WD 1982-1989 26mm 50 1/2" 1726 $330.00 Dodge V6 4WD 1990-1997 26mm 53 13/16" 1736 $300.00 Dodge 4x4/Raider 1990-1994 27.5mm 53 13/16" 1737 $220.00 i can go to any local junkyard and get both torsion bars on any year montero for under $50. <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> but still...nice reference <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Torsion Bars
[Re: ghostraider]
#954148
07/17/09 04:48 PM
wouldn't one of these work? (from sway away site) Dodge PU/Raider 4WD 1982-1989 26mm 50 1/2" 1726 $330.00 Dodge V6 4WD 1990-1997 26mm 53 13/16" 1736 $300.00 Dodge 4x4/Raider 1990-1994 27.5mm 53 13/16" 1737 $220.00 Yes you can get J/Y T bars but they are not the super duper improved aftermarket Sway-Aways.. i can go to any local junkyard and get both torsion bars on any year montero for under $50. <img src="/forums/images/graemlins/zombie.gif" alt="" /> <img src="/forums/images/graemlins/zombie.gif" alt="" /> but still...nice reference <img src="/forums/images/graemlins/kewl.gif" alt="" /> Also I belive there was a running change in the lenghth of the bars in the Gen 2's which is why they're listed as goin up to 94 in the Sway Away catalog. I know there is a member here with early gen 2 bars in his Gen 1 LWB. I think it was Sparkem.
99 Gen 2.5, fixing blown head gasket 89 SWB- 33's, ARB Front locker, SR rear locker/axle, SR F brakes, winch, WST Offroad Armor all Around, 2.85 Aussie T-case Gears (SOLD) Sold: (2) 95 SR's, 86 SWB, 90LWB, 91 LWB -Can Change a timing belt in my sleep..
Re: Torsion Bars
[Re: Mad_Scientist]
#954149
07/17/09 04:54 PM
I thought Gen1 and Gen2 torsion bars were different lengths. Didn't GrassCat try to install Gen2 bars and they wouldn't fit. May be wrong <img src="/forums/images/graemlins/cheers.gif" alt="" /> You are right, but, the bars I was trying to install were from a 1996 SR. Here's the post Gen II to Gen I swap update. I have not tried the non SR swap yet, need to find a set and do some measuring.
Michael j
TreadLightly! Trainer
